A/C not blowing air
A/C not blowing air
Hello guys, my A/C stop blowing air. One guy mention it could be the compressor, other said is the blower. I think is the blower because I here the compressor running. How i can diagnose this before going to a mechanic and he tells everything is screw?
thanks in advance
thanks in advance
With the engine running, have someone turn on the AC and see if the (electric)clutch engages. I'm not that familiar with Toyota's yet, but a common sign of low freon is a short cycling compressor. If the compressor is working properly (with a good charge) the suction line should be cool to touch and you'll see condensation on same.
Fuses, Switch, Component Location - 1986 MoreFunner
Blower relay and fuses for blower (blowing air) and air-conditioning (cooling air) are in dash, behind the cigarette lighter jack and to left of glove box
Schematic with notes on what you could quickly check without taking things apart is here:
Album URL: http://photobucket.com/rad4runner_hvac
Best of luck.
fixed
thanks in advance
thanks in advance
Tacoma1313
Aug 17, 2015 05:44 PM
klavender1
Aug 15, 2015 01:51 PM
