IFS taco diff
Old Jan 30, 2004 | 12:56 PM
RTdawgs's Avatar
IFS taco diff
i know that 96-02 4Runners have the same gears and housing as the 96-04 Tacomas, but are the diffs interchangable or do the Taco diffs have a different spline count than 4Runners?
basically, can a taco diff be put into a 4Runner without swapping axles and hubs?
Old Jan 30, 2004 | 04:01 PM
914runner's Avatar
i dont know, but why do you want a taco diff for?
Old Jan 31, 2004 | 11:07 AM
RTdawgs's Avatar
b/c it already has gears and a locker in it.
anyone know?
Old Jan 31, 2004 | 11:15 AM
Albuquerque Jim's Avatar
I think they are interchangeable.
Check out parts.com and compare part numbers.
Old Jan 31, 2004 | 11:26 AM
RTdawgs's Avatar
i couldnt tell by my searches. i know the carrier is the same and the ring and pinion are the same, but arent the CVs different?
Old Feb 2, 2004 | 09:23 AM
Breezey's Avatar
Guest
its all the same, as long as you have ADD and it have ADD.. also if you have v6 and it came from a V6 it should be the same. CV joins are all the same, only difference is on the hib site of a CV.. other then that, get it
Old Feb 2, 2004 | 10:55 AM
RTdawgs's Avatar
ok thats great news, thanks!
Old Feb 2, 2004 | 11:01 AM
data's Avatar
Senior Member
the diff already has a locker in it? what kind of locker is it? if you're only running a front locker be prepared to replace cv's left and right
Old Feb 2, 2004 | 12:02 PM
RTdawgs's Avatar
it has a Lockright and 4.88s
i def want the 4.88s, dunno about the lockright.
im going to install the diff and see how i like the Automatic locker, if i dont like, ill remove and ebay it.
Old Feb 2, 2004 | 12:48 PM
data's Avatar
Senior Member
If it were auto, i'd get manual hubs. I had a friend with a Taco with only a front locker and manual hubs. He broke cv's all the time. Seeing the 4runner is heavier, it might turn you into a pro 15 minute cv changer
Old Feb 2, 2004 | 06:25 PM
RTdawgs's Avatar
there are some guys in my TTORA chapter who have the Lockright with ADD. they love it! we'll see how it goes...
im more concerned about steering than stress on CVs.
Old Feb 2, 2004 | 07:00 PM
data's Avatar
Senior Member
Those guys running front and rear lockers or just front?
Old Feb 4, 2004 | 07:47 PM
Mad Chemist's Avatar
Do you already have 4.88's in the rear diff? For some reason, I don't think everything is the same for the 4runner and Tacoma front diffs, possible outer cv's are different? I'm thinking along the lines of the ORS kit and what needs to be changed to put on manual hubs, I realize its a somewhat unrelated topic.... Steve would be the one to chime in on this one.
Old Feb 5, 2004 | 07:15 PM
RTdawgs's Avatar
no.
For some reason, I don't think everything is the same for the 4runner and Tacoma front diffs, possible outer cv's are different? I'm thinking along the lines of the ORS kit and what needs to be changed to put on manual hubs...
im pretty sure the outer CVs are different, but according to others the diffs are the same. i think the HUB or KNUCKLE or something like that is what is different.
Old Feb 6, 2004 | 07:50 AM
So you're going to regear the rear diff at the same time when you install the front?
Old Feb 6, 2004 | 12:11 PM
RTdawgs's Avatar
yes.
i am slowly and surely collecting parts...
Old Feb 10, 2004 | 07:10 AM
RTdawgs's Avatar
Old Feb 10, 2004 | 06:17 PM
BajaTaco's Avatar
See my other post regarding the ADD actuators. Depending on the year of the Taco that is the donor, you may be getting vacuum actuated ADD or electric actuated ADD. Chances are that the ADD on your 4runner is the vacuum type ('98-'00)
justdifferentials
14
Jun 11, 2017 08:36 PM
skouba
Sep 14, 2015 06:58 AM
Flying91
Sep 10, 2015 03:41 PM
kportercpa
Engine Swaps
Sep 10, 2015 12:08 PM
zz_denis
Sep 6, 2015 03:43 PM
