93 pickup 3.0 auto to manual swap
ive been doing some research and plan on doing this swap pretty soon, i know ill need a clutch pedal assembly master cylinder flywheel clutch assembly hard line and soft line, and i know how to wire the harness to make the truck think its in neutral all the time, my only question is about the bellhousings, will a 22re bellhousing bolt to a 3.0 or will i need a 3.0 bellhousing to go to the r150f transmission, and also will my transfercase bolt right up to the back of the r150f? i plan on doing a write up as i start on this swap beings that i havnt been able to find one anywhere yet
extended cab, i found an r150f with a bellhousing for 140. my t-case of the auto should bolt up to the manual shouldnt it? sorry im not very knowledgeable with toyota drivetrains never really messed with them much
TheManOutside
Jun 18, 2015 03:32 PM
