Torque specs rotors/steering knuckle
I've got a 1992 Toyota Hilux 4x4. I'm doing brake pads and rotors. I need to know the torque specs for the wheel bearing hub to rotor bolts (the ones that connect the housing to the rotor. Also, should I use loctite on these. My second question is what is the torque spec for the steering knuckle to control arm? I've seen specs from 125-140 ft lbs. Also, do these need to be put in with loctite? I've cleaned everything and am ready to reassemble.
Thanks,
Jim
Thanks,
Jim
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
