manual temp gauge install
Old Jun 12, 2012 | 08:49 AM
BOTTLEROCKET's Avatar
where to install probe for manual temp on 91 22 r, the adapers wont thread into stock sensor ports
Old Jun 12, 2012 | 09:34 AM
DeathCougar's Avatar
The adapters are NPT, your truck is BSPT.
PM BigBluePile, he has a hose adapter that allows him to run an aftermarket temp gauge. Basically you splice the adapter into the upper hose before it goes into the radiator.
Summit and Jegs both sell the adapter
Old Jun 12, 2012 | 01:58 PM
10-4 2days tryin tofigure out..
Old Jun 13, 2012 | 12:11 AM
Chuckar's Avatar
Look at the upper radiator hose thats what it looks like installed.
Old Jun 13, 2012 | 03:51 PM
JohnnyCanuck's Avatar
THAT is a nice engine and engine bay.
Old Jun 13, 2012 | 06:06 PM
Philbert's Avatar
Hmmm....so I am currently that adapter (bought last year from Glowshift.com). My sender is dead and I just got a new one but I'm trying to track down a 22RE Turbo t stat housing that has two bungs for senders (1 for my oem one and 1 for my aftermarket NPT one).
Are there no adpaters from NPT to BSPT?
Old Jun 14, 2012 | 05:29 AM
scope103's Avatar
Like DeathCougar said: http://www.summitracing.com/parts/ATM-2269/
Old Jun 14, 2012 | 06:59 AM
Philbert's Avatar
Thanks scope!
I think cougard was referring to the hose adapter that I already have guess I could have searched for this one anyway, thanks for the legwork!
Old Jun 14, 2012 | 08:03 AM
irab88's Avatar
mcmaster.comm sells them for half that, plus you get next-day shipping for no added cost
p/n: 4860k141
Old Jun 14, 2012 | 08:45 AM
Philbert's Avatar
Thanks Ian - I don't know how I always forget about that site - they have EVERYTHING!
Now it's got me thinking again about replacing my cargo panels with diamond plate...need to measure the holes to choose the right Rivnut sizes
\threadjack
Old Jun 14, 2012 | 12:10 PM
Originally Posted by scope103
This adapter only works for oil pressure.
It will not work with temp sending units, because the sender has a probe that has to stick into the water stream.
You have to either A. Tap out a hole in your water jacket to NPT threads, OR get that hose adapter.
In my race car, I tried it both ways. The hose adapter ended up restricting water flow too much, so I pulled it out and tapped the OEM sender hole to NPT threads.
IF you are going to do that, I would suggest having it welded shut and redrilling/tapping instead of just retapping the threads further down into the manifold.
Old Jun 14, 2012 | 12:30 PM
Philbert's Avatar
Hmmmmm....well shoot. I have a welder (MIG) but I think that only would do steel and not aluminum? I haven't used it yet - got it a while ago for my chevy spring swap I haven't got around to yet....
Drilling/tapping a second bung in my OEM housing could work, but is that too risky, given the thickness of the walls and lack of an existing bung?
Old Jun 14, 2012 | 02:29 PM
You don't drill and tap into a hole that isn't already there. I tapped the stock sender hole with a NPT tap, and just went a little deeper into the hole. Since pipe threads are tapered, it cut new threads and held just fine. Knock on wood.
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
