question about gearing and mpg
I have a 2000 4runner and in running 35 inch tires. I changed out the stock 373 gears for 529s but my mpg has actually Decresed a little bit. Just wanting a little insight on some reasons this could have happend. Everything i have read said that 529s with 35 inch tires on my year 4runner would take it back to stock mpg. What am i overlooking here?
Your speedo is about 20-30% higher than stock. Use a gps with a trip meter and odometer to get your true readings.
No way you're getting 9mpg.
Also, forget "getting back to stock."
That ain't happening. You added a load of weight and pushed your brick at least a few inches taller which in turn kills all aerodynamics.
My guess is you're getting 14-17.
529 gears are kinda steep for 35's for running the hwy. 4.56 would have been a Lil better choice. But 5.29 gears are the better of the two when it comes to running trails and playing on the rocks. Like I was told years ago, are u building the rig for the hwy, or building it for the trails? Can't have the best of both worlds!!!!
This. Imagine how bad it'd been without a gear change. I'll bet you are doing fine on mpg, for 35s.
__________________
__________________
No, I meant 4.56, but ur right on ur gearing for tires!!!! Every yota I've built I went straight to 5.29 gears, but all my builds where trailer queens! They weren't built to run on the hwy! I don't run smaller than 38's on any of my builds
XtraCab
Apr 12, 2020 05:25 AM
Jnkml
Jul 6, 2015 01:20 PM
