Engine Swaps Swapping an engine in your Toy, here is where to learn how
22re vacume lines help!!!!!
Old May 20, 2012 | 03:49 PM
MikeJ827's Avatar
i need some help with all the vacume lines on a 88 22re the intake was off when i got it and dont know were all the vacume lines go and if some one has some pictures of the top of the motor and vacume lines would be great please help
Old May 20, 2012 | 04:44 PM
Mdumaw's Avatar
These are the only 2 i have from when i replaced the head gasket.
This truck is the 22R-TE and im not sure if the turbo vacuum routing is the same on the turbo as the non turbo.
and im only 95% sure their right but it worked for me!!
Hope this helps!
Edit: Note don't worry about all the ghetto wiring i have since then fixed that, the P.O. had some crazy stuff going on in this truck, notice the 4" ground with 2 butt connecters!!!
Old May 20, 2012 | 05:09 PM
ChefYota4x4's Avatar
Gotta run, but I have a couple youtube videos that explain where they all go, if you wanna look through em... imachefmang is my id on Youtube.... It's more toward the middle, I would say, of many videos, lol. I did 3 actually, and 1 is the best of them all.
Here's one for now, not the one I'm looking for...
Old May 20, 2012 | 11:25 PM
MikeJ827's Avatar
hey man what about the power steering ones because im putting it in a 85 and dont have power steering so do i just cap them off or
Old May 21, 2012 | 09:24 AM
Yeah, I suppose you would.
* So, you're not planning on power steering ever?
* Do you have A/C? (that has 2 lines running to the plenum as well, which have to be hooked the right way or you'll hear the filter basket tip 'HISSSSSSSS-WEEEEEEEE' away! lol.
* You have the IACV and large lines and plug to remember, too(just a heads up, it's a bit of a tight squeeze once everything's on )
*You might also have a cruise control line. That plugs into the 3 port attachment I showed.
Old May 21, 2012 | 10:16 AM
technojunkie's Avatar
When I rebuilt my 22re the first time I had the exact same problem, engine was disassembled, hood was in the bed. I spent hours working through the vacuum diagram in the Chilton manual. Afterward when I installed the hood I noticed a very handy decal showing the vacuum manifold and the lines that went from it to the individual parts. That decal was 100 times easier to read than chilton's diagram; so is there by chance a decal under your hood?
Old May 21, 2012 | 12:21 PM
Mdumaw's Avatar
i find it easiest to label the end of each vacuum line with a letter, and a corresponding letter where it goes. and PICTURES!! helps a lot.
Hope you get it figured out!!
Old May 21, 2012 | 05:49 PM
MikeJ827's Avatar
no i want power steering in the future just not right now i dont have the money to fork out for high steer and ˟˟˟˟ thanks this is helping me out
Old May 21, 2012 | 08:22 PM
No problem, Mike! We've ALL needed help on here, some of it desperate! ... And, well, some of us more than others YES< I mean me! hahaha. But actually, learned quite a bit through this site/it's peeps! lol.
Here's the hood diagram... DON'T feel bad if you have it and looked right past it(more than likely someone painted it! GRRR! lol. But if it's there, you're not the only person to have missed it! lol). >>>>>>>>>>>>>>>>>
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
ryerye13
Jul 14, 2015 08:27 AM
bryan34w
Jul 6, 2015 05:53 PM
