Extreme Oil Leak... HELP!!
Earlier today I hooked up a Direct fit exhaust manifold from LC Engineering and hung the rest of the exhaust. ran fine when it was idling, no leaks, sounded great! When I came back from my first trial run there was oil covering my alternator and pretty much the entire right side of the engine bay. I suspect the timing cover gasket has given out (gonna check it out tomorrow) but am wondering if this is purely coincidence or somehow that header is causing problems. Any thoughts?
My guess would be front main seal. The only way a headder install would cause an oil leak is anywhere you unbloted/removed something else (that is oiled) to get the headders in. Check anything you removed during headder install, then check front main. Could be it just decided that now was a good time to start leaking.
Update: Just took my power steering out of the system, still leaking, only under load and at above 3k rpm. spraying oil all the way onto the left side of the engine bay... looks like it might be coming between my timing cover and the cylinder head. what's in that area that is under that much pressure?
must not be my weekend, parked my yota and took out my 77 bronco for its first spring run...
washed it...
running great!
took it on a back road and the rear driveshaft blew up.
Thank god for twin stick!
washed it...
running great!
Found the problem, the top left bolt (drivers side) on the timing cover holds my alternator bracket in place, it was just past finger tight. snugged it with some loc-tite and it's holding just fine.
jasonty
41
Dec 23, 2018 01:00 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
