Extreme Oil Leak... HELP!!
Old May 10, 2012 | 08:28 PM
cheapneasycrndog's Avatar
Earlier today I hooked up a Direct fit exhaust manifold from LC Engineering and hung the rest of the exhaust. ran fine when it was idling, no leaks, sounded great! When I came back from my first trial run there was oil covering my alternator and pretty much the entire right side of the engine bay. I suspect the timing cover gasket has given out (gonna check it out tomorrow) but am wondering if this is purely coincidence or somehow that header is causing problems. Any thoughts?
Old May 10, 2012 | 08:37 PM
Anybody else running these headers experience anything like this?
Old May 10, 2012 | 09:40 PM
ksti's Avatar
Did you take the distributor out?. If so I'm just wondering if the o-ring isn't sealing causing oil to leak on alternator. Just a thought. Good luck
Old May 11, 2012 | 04:55 AM
I haven't taken it out since it started leaking, I installed a new O ring a couple weeks ago... the power steering pump is dry so it looks like it's blowing out below that.
Old May 11, 2012 | 06:56 AM
Bingle's Avatar
My guess would be front main seal. The only way a headder install would cause an oil leak is anywhere you unbloted/removed something else (that is oiled) to get the headders in. Check anything you removed during headder install, then check front main. Could be it just decided that now was a good time to start leaking.
Old May 11, 2012 | 06:59 AM
gennro's Avatar
Power steering hose busted
Old May 11, 2012 | 02:30 PM
Update: Just took my power steering out of the system, still leaking, only under load and at above 3k rpm. spraying oil all the way onto the left side of the engine bay... looks like it might be coming between my timing cover and the cylinder head. what's in that area that is under that much pressure?
Old May 11, 2012 | 02:31 PM
btw when I took out the dizzy the o ring looked great still, no tears and the bottom of it is dry. (it'd have to hit it to if it was spraying out.
Old May 11, 2012 | 05:54 PM
must not be my weekend, parked my yota and took out my 77 bronco for its first spring run...
washed it...
running great!
took it on a back road and the rear driveshaft blew up.
Thank god for twin stick!
Old May 15, 2012 | 07:17 AM
Found the problem, the top left bolt (drivers side) on the timing cover holds my alternator bracket in place, it was just past finger tight. snugged it with some loc-tite and it's holding just fine.
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
calderp
Jul 27, 2015 09:58 AM
