Weber Issues
Old Feb 13, 2012 | 05:25 PM
yotaman1861's Avatar
Weber Issues
ive got an issue with my weber and hopefully someone can help. This past saturday i went to crank the truck. turned the key pressed the fuel pedal to the floor and turned the engine over, it would fire but then sound like it flood it self out. I could hold the fuel pedal 1/4 open and it would run but it was missing, had to much fuel. Once i get it warmed up it runs like a top. Ive checked for leaks, plugs and timing. Ive had the carb on the truck for approx 5 months, and it just started this all of a sudden. Any ideas?
Old Feb 13, 2012 | 05:57 PM
waskillywabbit's Avatar
Please don't jack someone else's thread. Start your own
:wabbit2:
Old Feb 13, 2012 | 06:21 PM
I apologize for that, Thank you for moving it.
Old Feb 13, 2012 | 06:34 PM
yotaman85's Avatar
dont mind wabbit, he doesnt get enough sleep!. im sure XXX will be here soon. in the mean time make sure you dont have any leaks, check to make sure the carb is tight and the linke is free and clear and lubed. it might be sticking while cold and when hot it frees up.
Old Feb 13, 2012 | 06:39 PM
haha wabbit is the best. I ordered a one piece trans-dapt adapter for the carb, the two piece that came with it leaks a little but it has done that from day one and i havent had any issues, do you think that could of caused my problem all of a sudden?
Old Feb 13, 2012 | 06:50 PM
JonnyBoy's Avatar
Did the problem start right away when you switched the adapters? Was the carb tuned for lean best idle when it had the 2 piece cast adapter that was leaking? If so, you may now be running slightly rich, and when it's cold they run richer to warm up.
Old Feb 13, 2012 | 06:54 PM
yotaman85's Avatar
the 2 pice adapters suck. it could be the problem.
Old Feb 13, 2012 | 07:02 PM
okay, ill give it a whirl. hopefully this will solve the problem. Hopefully ill be ordering a clutch kit from wabbit this week as well. thank you!
Old Feb 13, 2012 | 07:28 PM
I havent switched adapters yet, i just have the weber at factory settings and it has ran good the whole time ive had it on until this past saturday. i will give the one piece a whirl and re-adjust the carb this week sometime. its running a lot rich right now. horrible fuel milage.
Old Feb 13, 2012 | 08:25 PM
JonnyBoy's Avatar
Well, that would be the opposite of the problem you'd have if the adapter pieces were leaking. Do you have a fuel pressure regulator installed? Return line from the fuel pump blocked off? If yes to the regulator and/or no to the return line blocked off, I think I'd suspect something breaking free that was plugging something up or something like that. There's a pretty low probability that something is now lodged in the accelerator pump circuit causing it to stay open, but I s'pose that's possible too.
Not that I suspect you of something here, but you did nothing to the carb right before the issue? No changing the idle, no changing the choke, no changing the fuel filter, etc? Is your timing still spot on where you left it? It could be some relatively unrelated thing that just affects the burning of the fuel and not the delivery.
Old Feb 14, 2012 | 06:32 PM
Alright, I changed the adapter plate today. I have a fuel regulator on the truck at 3.5 psi. I hooked everything back up and still the same thing. So i started to mess with the choke and the fast idle according to instructions and that seems to be the culprit, it cleared the rough start up some but i still gotta get the few remaining gremlins out of there. I think im headed down the right path. Thank yall for the responses!
Old Aug 15, 2012 | 02:01 PM
lineman2190's Avatar
Just put weber on an 82and drove it ran good Idle a little high .went back to crank it.and it acted liked it was hydro locked.Any body had that promblem before?
kazuya2416
Apr 5, 2024 02:17 AM
PNWrider
Oct 30, 2015 08:14 AM
God's Bounty Hunter
Oct 23, 2015 09:44 AM
priest16
15
Aug 6, 2015 07:43 AM
mikeyd6789
Aug 4, 2015 11:51 AM
