Help for wiring up key barrel
G'day
I've got a 22R 89 hilux and i want to install a push button start.
From what i can see, i should use wire 4 and 8. tap into wire 4 and run to the 1st prong on button and tap into wire 8 and run to prong 2 on the button.
Would that be the correct procedure? I've attached a pic i scanned from my manual.
Thanks
Thanks
I have an aussie made Holden Commodore. I ran the same press button starter switch straight off the back of the barrel. I tapped into a pink wire and a blue or green wire. The workshop manual for that is alot more detailed than the toyota manual i got(both from the same company)
It worked fine for 2years until i removed it to sell the car.
Yeah what you said pretty much. Still able to start with a key. I guess it is kinda pointless. 1 of the keys has the end broken off in the ignition and that key doesnt unlock the doors. I usually leave the broken key in the ignition. I will be installing a basic kill switch in a hidden spot.
Hey man I had this done to my truck because my kkey tumbler went bad and couldnt find a replacement. I didnt do it, but i know the basics of what he did. You need two switches, one for run, one for Accessory. and then the actualy push button. i wouldnt reccomend it because anyone could get in your truck and drive off without a key.
The start circuit has 2 wires that need to go connected if you want at least a push start button. ( not ignition or acc). there are 2 starter wires (pin 1 & 2), for that you need 2 relays. Do not put them together it will work but cause problems! these 2 starter wires are separate for a reason, let me know if you need a relay diagram to get this done, thanks
theking11863
Mar 19, 2016 09:36 PM
Hamonacracker
Jul 17, 2015 08:33 AM
