Pre 84 Trucks 1st gen pickups
Help with AC connection '79-'83
Old Jan 15, 2012 | 03:50 PM
bat_mobile's Avatar
Guys/Gals,
For those of you with AC in your trucks, could you please tell me, or better yet, show me with a pic where this green plug plugs into? This is off the box directly below the glove box, underneath the dash.
Thanks in advance for your help.
Old Jan 15, 2012 | 04:12 PM
suncomb1's Avatar
Belongs to the AC Amplifier card circuit. The AC Amplifier card is located in a small compartment on the AC unit and a matching connector should be on the wiring harness going to the engine compartment and AC Relay (4x4).
Old Jan 15, 2012 | 07:16 PM
bat_mobile's Avatar
Suncomb1
My '82 did not come with a factory AC. But I was able to verify that although my truck did not come with AC from the factory, it does in fact have all the wiring and connections FOR a/c as a part of the harness.
Where I'm getting lost is beneath the glove box. Can you tell me where I could find the AC relay?
Pics would be great.
Thanks for your help.
Old Jan 16, 2012 | 02:52 PM
suncomb1's Avatar
Sorry, I can not take a photo because my truck is in storage but here is what I can give you. 1-8 Pole plug on the wiring harness plugs into the AC amplifier, 1-2 pole plug goes to the pressure switch, 1-2 pole plug goes to Thermister, 1-2 pole plug goes to the Control Resistor, 1-6 pole plug connects to the engine harness, 1-4 pole plug goes to the Water Temperature Switch relay (round relay) (located on the passenger side, up near the seat belt warning relay), 1-1 pole plug goes to the Water Temperature Switch (located on the cylinder head near the center of the intake manifold). You should have a VSV (Idle up) on the passenger side inner fender close to the firewall 1-2 pole plug. This increases your engine idle when the AC Compressor comes on. Hope this info helps.
Old Jan 17, 2012 | 02:02 AM
bat_mobile's Avatar
No worries.
I finally figured it out. Thanks for the responses. Very helpful in pointing me in the right direction.
I once did a an a/c swap into an '89 Nissan Sentra. Tedious and time consuming, but I got it to work. I must say swapping in a factory a/c system in these trucks is 100x easier! Love it.
Steven.m.paulk
Jun 7, 2020 10:45 AM
puddlepirate
Sep 29, 2015 08:02 PM
voiddweller
Sep 28, 2015 11:21 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
