Sponsored by: CARiD
Rear end vibration driving me crazy
Old Dec 10, 2011 | 11:54 AM
mjeffy's Avatar
I have vibration issue in 2003 tacoma double cab with 184000 miles 4 wheel drive with trd,while accelerating. When I let off the gas vibration goes away as soon as I get back on the gas it rattles my whole dash. All u-joints are tight. When i lift both rear wheels and spin tires I can hear the clunk and wheel has some play passenger side is worse than driverside. Also with wheels up engine on and in gear i can see the wheels wobble around 80 mph. Is this symptoms of axle bearings or something in the rear diff ?
Old Dec 10, 2011 | 01:44 PM
skypilot's Avatar
Could be the bearings in the rear axle are shot after so many miles. Time for a rebuild. I bet you have a pinion gear wobble too? Maybe with an oil leak? I bet no one ever changed the gear oil in all this time. Could be nothing more than normal wear and its time has come.
And I bet the u-joints are shot too you just cannot see them moving around. Mine lasted a little over 200k so yours cannot be far behind.
Old Dec 10, 2011 | 03:34 PM
mjeffy's Avatar
I ll bet you are right about time for a rebuild. i did change rear diff oil about 50,000 miles ago. I guess i will drop drive saft out and check u joints and change pinion gear while i am at it!!! Thaks again for reply.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
red88toy
11
Aug 3, 2015 07:47 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
