Sponsored by: CARiD
buying a '90 4runner with blown hg tonight
Old Nov 2, 2011 | 08:44 AM
JohnVH's Avatar
My first post, been looking for one for a while, excited to dig into it and make a driver, any advice? Its a 3.0 he says. 5speed, supposed to be in good shape.
I looked a little on swapping for a 22r but that seems like a spendy way to go, so Ill probably just fix the v6 right?
Thanks
Old Nov 2, 2011 | 09:03 AM
waskillywabbit's Avatar
Read the 3.4 swap section.
:wabbit2:
Old Nov 2, 2011 | 09:07 AM
JohnVH's Avatar
Ok, but trying to do this on a low budget, do not want to spend much money on this thing if I dont have to.
Old Nov 2, 2011 | 10:13 AM
1800's kinda guy's Avatar
3.4 is way too expensive if you are on a low budget. and a 22re swap is too. just do head gaskets. will still be a grand or more, but cheaper than the other.
Old Nov 2, 2011 | 10:18 AM
MaK92-4RnR's Avatar
direct 3.4 swaps are very cheap. ( as in pull the motor from one vehicle and drop it into the other ) given that you have all of the tools to do it...
Old Nov 2, 2011 | 10:38 AM
I've got $0 in my 3.4 motor swap after selling off parts from the donor vehicle.
:wabbit2:
Old Nov 2, 2011 | 11:14 AM
granted if you know how to do all of the wiring and mechanics yourself, but for your average joe, they are gonna take it to a mechanic which isn't gonna be cheap. that's what i was getting at.
Old Nov 2, 2011 | 11:20 AM
JohnVH's Avatar
a grand to do the head gaskets?
Old Nov 2, 2011 | 11:25 AM
not on your own of course, but isn't that what most mechanics charge to do it? including parts. or is that just when you do timing belt, and water pump at same time?
Old Nov 2, 2011 | 11:34 AM
JohnVH's Avatar
I dont know, never taken a rig to a mechanic. I know they wanted $3500 in labor to do my duramax headgaskets when it blew up... did that one myself too.
Is it easier to just pull the motor out to do this? Or should I do it in frame?
Old Nov 2, 2011 | 11:38 AM
in the frame for sure.
Old Nov 2, 2011 | 11:42 AM
if i were you, i'd check the timing belt. your already gonna have it torn half way apart, so it may be preemptive maintenance to do the timing belt and water pump while you are there.
JohnVH's Avatar
Ok thanks, Ill do a thread with pics on it for others like I did with the dmax. Hope its not too much of a pita! This will be my first toyota, want to do what I can to make it reliable and live a long time!
Old Nov 2, 2011 | 02:19 PM
gagnier6996's Avatar
Definitely a very good idea. I would just do head gaskets and T-Belt while you are in there and enjoy the truck.
cheers!
Old Nov 2, 2011 | 02:25 PM
JohnVH's Avatar
and knock sensor?
Old Nov 2, 2011 | 05:55 PM
JohnVH's Avatar
Just got home with it, perfect body and interior, power everything, sunroof, all door locks, windows, rear window, works. Aftermarket wheels, CD, AC, excited to get this thing going! Ill get some pics tomorrow, and go get a chiltons and order some parts.
Old Nov 3, 2011 | 11:40 AM
JohnVH's Avatar
So general concensus is no felpro head gaskets? I noticed they tried bars leak on it, hope they didnt plug the heater core.
Also, anyone know of any engine diagrams on the net? Been looking for info on this job.
Hope to have enough time to tear it down this weekend and see whats really going on in there.
gave up on uploading, hope this pic works better. Forum wanted a postage stamp.
Old Nov 3, 2011 | 12:02 PM
Abnormal's Avatar
You have a lot on your plate... Hope everthing goes as plan
Old Nov 3, 2011 | 02:07 PM
JohnVH's Avatar
Question
Just called dealer, here is the toyota prices for the parts...
- gasket set $380 (should have everything including head bolts) Kit at schucks with fel pro's was $240
- headgaskets alone are $64 each
- Headbolts alone they said $1.35 each
- Timing belt $45
- Knock sensor $240!!!! the wire for it is $15
Here is a great resource for manuals
http://www.ncttora.com/fsm/index.html
Old Nov 3, 2011 | 03:08 PM
Terrys87's Avatar
8T8 build thread has alot of details and pics. Give you an idea what all is needed.
Here is their build thread. They have probably done alot of the legwork for you on where to get parts and such.
https://www.yotatech.com/forums/f199...thread-197690/
