1985 Pickup Steering help.
Old Oct 26, 2011 | 05:05 PM
Jharvey's Avatar
Exclamation 1985 Pickup Steering help.
Hey guys i need help with my steering. I have ALOT of play in my steering which makes me look like a drunk while driving. Also, when i get on the brakes the steering pulls HARD to the right. Its a big problem for me.
My rig is a 85 pickup with 6inch lift 35's if that helps.
Old Oct 26, 2011 | 05:23 PM
Toyota Pete's Avatar
Your best bet is to ditch the stock steering and go with the Hy-Steer Crossover unit. I have an 81 with 36" tires and lift and it made all the difference in the world.
Old Oct 30, 2011 | 10:04 AM
hrt4me's Avatar
My rig is a 85 pickup with 6 inch lift, 35s if that helps.
I'm having a similar issue with my 1st Gen '85 4Runner, but only 2" lift and 32s... what does the hysteer crossover kit involve?
Old Nov 2, 2011 | 09:24 AM
6th Gear's Avatar
Pulling left or right when braking can be a sticking caliper. Calipers don't like to be submerged in mud.
Old Nov 2, 2011 | 09:56 AM
1800's kinda guy's Avatar
you can also get bushing kits for the j arm connections online somewhere. they aren't too bad to change and make a BIG difference!
Old Nov 2, 2011 | 11:52 AM
4runner Freak's Avatar
Assuming that your calipers aren't sticking and making it worse,
You need one or more of the following:
1. An anti wrap bar,
2. Steering swap to cross over,
3. Modify and reattached the torque bar when you're on the road
4. Double check that your u-bolts, shackles and hangers are torqued correctly, new drag link bushings and deal with what doesn't go away.
When I lifted my 4runner I got the same issues.
I tightened my u-bolts(They had loosened up, slightly) and learned to deal with it until I changed to crossover steering.
Because of the push-pull steering, the axle wrap causes the steering to pull when breaking.
Old Nov 2, 2011 | 11:54 AM
4Crawler's Avatar
Has the stock torque rod been removed?
Old Nov 28, 2011 | 11:39 AM
Sleepr71's Avatar
I'll just add that my torque arm had gotten loose & I was experiencing a lot of wandering,as well as diving hard to the right on braking! First area I would check/tighten up is BOTH torque arm bolts,then the calipers..then go from there! HTH,Sleepr71.
Old Nov 28, 2011 | 04:41 PM
hrt4me's Avatar
do you happen to have any pics of the torque arm bolts?
Old Dec 2, 2011 | 08:33 PM
jswizz's Avatar
Yes ,DITTO THAT pics of arm or bolt this may also be my problemb
Old Dec 3, 2011 | 05:34 AM
waskillywabbit's Avatar
Removing the stock torque bar makes it pull when braking.
High steer is your best fix for a lifted SFA Toyota.
:wabbit2:
Old Dec 5, 2011 | 10:40 AM
rokblok's Avatar
I have to agree that Hysteer is the only way to go...
Charecter1
Nov 6, 2023 10:08 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
bryan34w
Jul 6, 2015 05:53 PM
