put in 4 inch bracket lift, front driveshaft wont hook up
i just put in my lift today and the front driveshaft wont angle low enough to hook up to the diff. i had diff drop spacers but took them out but the shaft still wont hook up. its a 93 ext cab truck
Thats odd. When I lifted my front end with 4-inch bracket lift kit, I had no issues in connecting the stock driveshaft. It obviously is far more extended then it was originally.
Did your driveshaft extend? It has some room built-into the stock driveshaft to extend a few inches and mine was enough to connect. Im just wondering if the driveshaft on your truck is frozen due to rust, age, etc.
But, yaah, there should be no issues in using the stock driveshaft .. even the lift kit instructions do not mention that you need to resize your driveshaft.
On the IFS trucks, there is a shield that mounts around the front output of the transfercase.
Remove this shield and the driveshaft will drop further and mount up just fine....
Since
must be down or something here is what Wabbit was talking about:
http://www.4x4wire.com/toyota/tech/cvmod/
Or go to a driveshaft shop.
must be down or something here is what Wabbit was talking about:http://www.4x4wire.com/toyota/tech/cvmod/
Check the way you have the drop bracket on the axle tube on the driverside on....I know that one way angles its down the other angles it up....it will bolt up just fine either way...it almost tricked me....I put my lift in a few days ago.
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
