uneven misfire, any ideas?
Old Aug 9, 2011 | 07:51 PM
twistedyota's Avatar
so my red 4runner has had a misfire for 3-4months now. i havent done anything because i had no money. but now with my job i have some money. so i looked at all my plugs and they looked good, looked at my wires they are getting old but still good, looked at my caap and it had some build up on the points. so i ordered a new cap and rotor.
installed the cap and rotor today and still no change. swap wires from the grey runner tht runs good and still nothing, and all my injectors are pulsing properly.
the wierd thing is tht it isnt a constant mis-fire. is like an uneven one and it doesnt seem to change at higher rpms, like a regular mis would increase as the rpm's increase.
so im at a stand still.
Old Aug 9, 2011 | 07:55 PM
MattD's Avatar
Unplug the vacum line off your egr valve and plug it, see if that helps any.
Old Aug 9, 2011 | 08:22 PM
andrewflores17's Avatar
does temp make a diference at all with it
Old Aug 9, 2011 | 10:54 PM
85gijunk4x4's Avatar
valve lash.
might've knocked one loose poppin' wheelies
Old Aug 9, 2011 | 11:14 PM
Toyota745's Avatar
i had problems with my fuel pump, injector, but those had slightly different symptoms. i did have that problem at one point, it turned out to be a combination of a junk MAF, and broken throttle body position sensor wires
Old Aug 10, 2011 | 03:40 AM
TNRabbit's Avatar
Start with checking for vacuum leaks. Check your intake for cracks.
Old Aug 10, 2011 | 04:55 PM
ill try tht either tomarrow or friday
let me look tomarrow morning and i will let you know.
Originally Posted by 85gijunk4x4
valve lash.
haha, no its not the valve, haha
my uncle told me to check my maf, so i will swap the one from my good truck tomarrow.
will do.
Old Aug 11, 2011 | 02:18 AM
Terrys87's Avatar
Hello Twisted.. I had a similiar problem. Might try making sure all of your injector connections are making good contact. If your injectors are locked down with the wire clip, the ends tend to get brittle and break off.
If you have the newer version of injector connections, with the little squeeze tab, I am not sure what it could be.
Old Aug 11, 2011 | 09:21 AM
i have the old style with the wire clip. but i put a test on the injectors and it showed them all firing evenly
corey519
Aug 12, 2015 11:12 AM
256mbaker
Jul 31, 2015 06:45 PM
pyramid
Jul 30, 2015 10:05 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
