How Many Miles on Your 3rd Gen 4runner Timing Belt?
Old May 23, 2011 | 03:22 PM
Smallwood0507's Avatar
How many miles do you have on your third gen timing belt?
I have 70,000 miles.
Old May 23, 2011 | 03:31 PM
warpigg's Avatar
as far as i know 177,740 miles
95blackToy's Avatar
My 3.0s timing belt never went out and i replaced it at about 180,000 miles when the head gaskets blew. That thing ws definatly on its last leg though.
Old May 23, 2011 | 05:59 PM
J2F42C's Avatar
100,000; on a 99 made in 10/1998. Both the TB and H20 pump are still ticking along.
Old May 24, 2011 | 06:43 AM
throwsomedeez's Avatar
178k here on a 98 Limited
Old May 24, 2011 | 06:56 AM
JAvendan's Avatar
had it changed along with the water pump at approx. 107k on my wife's 2000.
joel
Old May 24, 2011 | 06:58 AM
Elton's Avatar
i had over 120k on mine tell the water pump seized at 188k just glad i was only a few miles from home i put in a really nice ebay kit job wasn't that bad
Old May 24, 2011 | 05:25 PM
beachclown's Avatar
Only 85,000 on this one changed the first one at 95,000.
Old May 24, 2011 | 07:51 PM
rhill's Avatar
dang, are the 3rd gen motors free-wheeling? you guys are crazy if they aren't...
Old May 24, 2011 | 10:04 PM
TheDurk's Avatar
...if you mean non-interference, they most certainly are. But read the whole thread (I did once); the cases of TB failure at high mileage are few and most are actually caused by WP leakage or seizure.
Old May 25, 2011 | 08:33 AM
rhill's Avatar
just because you don't throw a rod doesn't mean you shouldn't change your oil...just because your plugs still spark doesn't mean you shouldn't replace them...just because your air filter hasn't disintegrated doesn't mean you shouldn't replace it...
just because your timing belt doesn't fail doesn't mean you should leave it on for 200k miles
Old May 25, 2011 | 11:29 AM
TheDurk's Avatar
Totally agree. But I decided to change mine at 120K and I am quite comfortable with that interval; I changed WP, tensioner, and both idlers, too. I'm good for another 120K.
Old May 25, 2011 | 01:11 PM
Brutus's Avatar
Mine was changed at 120,000. Now have 244,000 and I'm not sure when I plan on changin it.
Old May 25, 2011 | 01:36 PM
tunnelmotor99's Avatar
I wish I knew if and when mine was changed. We bought the 4runner almost 2 years ago and I took the cover off and inspected everything and it all looked fine so I'm assuming someone had it replaced in the 172k miles it had on it. Now I'm about to hit 190k and I have a new belt, water pump, tensioner and idler pulley ready to go on when they're needed.
Old May 26, 2011 | 09:44 PM
ESQ's Avatar
ESQ
70,000 km
Old May 28, 2011 | 09:01 PM
trailmix's Avatar
Just did the timing belt water pump, idler pulley, tensioner etc on 96 runner with 196k i just picked up and the timing belt and water pump looked original but the belt wouldnt have lasted much longer, is way dried out and cracked.
Old May 29, 2011 | 12:15 AM
awdjunkies's Avatar
Love the sound of this, since I am looking to get into a 3rd gen.
Old Mar 22, 2014 | 05:57 PM
madcanvis's Avatar
Bought the truck with 150k miles a few years ago. I now have 199,570 and brought it in for TB and water pump. I asked the mechanic if it was the original "I can't be sure. but if it isn't the worst one I've ever seen! It was full of chips and cracks." -he's been working in his old mans shop for at least 20 years. Yikes!
Old Mar 24, 2014 | 04:07 AM
Robb235's Avatar
I assume 240,000 miles on mine...
Only because I'm not sure if the previous owner ever replaced. I'm the third owner. Second owner said he never replaced, but was unsure if the first owner ever did. I haven't found any signs that it's ever been replaced.
I have the new TB, WP, etc. sitting in the back seat. I keep telling myself I'll get around to changing it...
Old Mar 25, 2014 | 02:19 PM
aowRS's Avatar
I went 170,000 miles on the factory setup before having the TB, WP & belts replaced.
That set now has 130,000+ miles on it. I think I'll wait until 350,000 miles for TB job #2...
Andreas
