How Many Miles on Your 3rd Gen 4runner Timing Belt?
Old Mar 25, 2014 | 02:34 PM
TheDurk's Avatar
Originally Posted by aowRS
I went 170,000 miles on the factory setup before having the TB, WP & belts replaced.
That set now has 130,000+ miles on it. I think I'll wait until 350,000 miles for TB job #2...
Andreas
Impressive--what coolant and change interval do you use? (I went 120k and chickened out.) I'm not surprised by the belt, they hardly ever break, but that's great mileage on a WP.
Old Mar 25, 2014 | 02:51 PM
aowRS's Avatar
- Toyota red coolant
- 170,000 miles
(I did install a new Toyota radiator at 200,000 miles as preventative maintenance.)
Andreas
Old Mar 25, 2014 | 03:05 PM
arkninjazx9's Avatar
223,000.........then the head gasket gave up and we swapped out the engine for a 90,000 mile one
Old Mar 25, 2014 | 03:28 PM
TheDurk's Avatar
- 170,000 miles
Andreas
Dang! Was it still red?
Old Mar 26, 2014 | 04:19 AM
  #25
aowRS's Avatar
Yes.
Andreas
Old Mar 29, 2014 | 06:46 AM
  #26
jfrahm's Avatar
Dang indeed. When I got my 1998 3.4L at 180K miles I changed the leathery timing belt and water pump and also had to breaker-bar the original spark plugs out of the heads. The gaps were over 2x the spec but the truck ran the same and got the same MPG before and after. I replaced the fan support, rollers, etc. and also the front O2 sensor.
With an eye towards not sleeping in the woods in a broken-down truck I swapped in a low-mile alternator thought the OEM one was in decent shape, and I replaced the fuel pump and fuel filer. After the starter made a grinding noise a couple times I bought a rebuilt one, but the purchase alone seemed to be enough to get the old starter to behave and it's never acted up again so the rebuilt starter is in the shed. Recently I replaced the TPS just figuring it probably had a worn spot in it. It's cheap and easy.
The fuel pump I figure is a good prophylactic repair as when they get worn the brushes can break up and jam up the works. On the trail you can sometimes reverse the wires to get them unstuck, and then switch them back to forward and get back to town but I'm OK with just replacing it before it wears out.
Re: spark plugs you can tell they are from the factory sometimes as you might (should?) see two different brands, one on each bank. That was true in my case.
It's insane how much skipped maintenance these things will tolerate.
-Joel.
AustinTaco
Aug 22, 2022 10:45 AM
vasinvictor
Jan 20, 2016 12:39 PM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
