22RE No Oil Pressure after oil pan gasket replacement
So is that all you did was just remove the pan and replace the gasket? Did you remove the pickup at all? There should be enough oil in the system so it wont need primed, usually when you prime an oil pump it is when you just rebuilt the engine so oil is not throughout the system already. The only way that you could prime it is by turning the oil pump, but like I said, you should be good, how do you know there is no oil pressure? Is the engine knocking when you start it? How long has it ran since you did the gasket?
How are you determining lack of oil pressure?
And x2 on making sure you put oil in and x2 on checking the oil pressure sender connection, if using the stock sender and light/gauge. I found that about half the time I touched my filter or pan, I knocked the sender wire loose and gauge read 0 psi. I have subsequently torn the connector apart and re-bent the brass inside to fit tighter and have had no issues since. This is with the factory gauge sender with the heavy rubber boot over it. Problem is there is no way to see the connection with the boot installed, so you basically need to pull it off, re-install the connector then slide the boot over the top.
Yes. Oil was put back in.
Originally "gasket maker" was installed on the oil pan and it still leaked so the seller installed a gasket. It had oil pressure before the gasket was installed and now it does not.
Last edited by Landlockt; Apr 20, 2011 at 02:09 PM. Reason: clarification of who was doing the work
Actually RTV is the correct way according to Toyota, you still have not answered the question of how you are determining that it has no oil pressure.
No oil pressure at dash gauge.
All that was done was pull the pan and reinstall so I am assuming the sending unit wasn't damaged.
And yes I know what they say about assumptions.
Can you use a compression tester to test the oil pressure?
p.s. This is actually a truck that is for sale. I haven't done any of the work.
The wire is very easy to bump with the pan and lose connection like already stated, just look at it real quick, pull the rubber boot back and make sure that it is connected, it is located right in front of the oil filter. A compression tester is not going to tell you anything about oil pressure and if it really has no oil pressure, you don't want to do a compression test as the rods will be spinning on the crank with no lube.
I don't think you can, because a compression tester meant for engine pressure probably wouldn't have a low enough reading to test oil pressure.
Worst case is that you may have got something in the oil pan like old RTV and it is clogging the pickup, thats all that I can think of if all you did was take the pan off and on other than a sending unit issue.
Ive seen this many a times before.
I dont like using RTV gasekts, i will make my own gasket before I use RTV only on an oil pan. I will use a thin layer to bond the gasket in place for install only.
I know this is an old thread but I have the exact same problem. I replaced my front third and while it was out I replaced the leaky oil pan gasket. Now on startup my 22re has no oil pressure and a weird sound for 15to 30 seconds. I bought a new pickup tube and when I have a chance I will tear my truck apart and see if I can fix it, but until then any ideas did I damage the oil pickup, clog it, f something else up?
93 toy 4x4 extra cab 285000 miles
