torque specs. '85 22R
Old Aug 9, 2002 | 09:31 AM
growinseed's Avatar
Hey folks,
New here, found you via toy trucks newsgroup. I have a few questions. I'm looking for the torque values for the following:
Details: 1985 22R carborated 4x4 pick-up
water pump to timing cover
oil pump to timing cover
timing cover
chain tensioner to block
chain guilds (dampers) to block
Oil pan
Oil return? in the pan with the screen (can't think of name, duh)
I think I have the rest in Hanyes manual
Also beside the oil pan does anyone use 'gunk' (silcone) anywhere at reassmebly
Felt it was time to do chain @ 297K
Nathan
P.S. anyone out there have the factory repair manual they want to part with:-)
Old Aug 9, 2002 | 05:00 PM
Shane's Avatar
Re: torque specs. '85 22R
I assume you've already disassembled everything so you know about the hidden bolts?
no info in factory manual, assume same values for timing cover
top bolt - 18 ft-lb
side bolts - 14 ft-lb
bottom bolts - 9 ft-lb
relief valve plug - 27 ft-lb
timing cover
8mm bolts - 9 ft-lb
10mm bolts - 29 ft-lb
no info in factory manual, I use same value as for cover.
no info in factory manual, I use 9 ft-lb and threadlock.
Oil pan
9 ft-lb
Oil strainer/pickup? 9 ft-lb
At the point where the timing cover, block, and head meet on both sides. Also the half-moon rubber plugs on the valve cover, goop them up good.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
