Sponsored by: CARiD
pre 88 fuel sending unit
Old Mar 18, 2011 | 07:23 AM
FattMaanLittleTruck's Avatar
I have an 86/87 pickup.
My gas gauge almost always says empty unless I fill it. (then it says full for a day or two)
I am having trouble tracking down a fuel sending unit. (one without the fuel pump and just the float) I looked on napa vatozone and ebay.
Old Mar 18, 2011 | 07:37 AM
xxxtreme22r's Avatar
www.toyotapartszone.com www.toyotapartseast.com or your local dealer. They are expensive and the right ones are not available from places like autozone napa etc etc. The only ones I think I hae seen on autozone were the later model ones with the low fuel level warning.
I started a thread a while back with part numbers and such, but if you go the junk yard route there is only a few that will work depending on ext cab, single cab, years, gas tank size and weather or not you have a gauge cluster that has a low fuel level warning.
oh and they are not single piece units, the fuel pump is completely separate which is evident when you look at the tank, there is two holes in the top of the tank, the one towards the rear is the actual level sensor/sender. The one in the front is for the fuel pump/fuel pickup only.
Doug4320
Mar 24, 2018 10:11 PM
gary4runner
Sep 24, 2015 12:53 AM
skoti89
Sep 11, 2015 07:46 AM
Odin
Jul 15, 2015 09:28 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
