22r smoking after head job!!!!
Old Feb 24, 2011 | 08:48 PM
Xjtim's Avatar
So I have an 85 longed 22r, 5spd, and it's 2wd(that part I'm debating on an SAS). Anyhow, I did a head job a few years back to replace the valve stem seals. Once I had everything put back together I fired it up and it smoked really bad, it was burning oil. It fouled my plugs in about 50 miles. I ran it about 100 miles like that till I put my little yota on the shelf and bought a...don't kill me...jeep cherokee(xj, hence the name)...anyways I want to get my yota back up and running so I can start my build. Any ideas? I've heard that if you seal up the top end of these motors it will blow he bottom end out. Any truths? Any help would ne much appreciated!
Old Feb 24, 2011 | 09:09 PM
mightymouse's Avatar
welcome to the forum. Sounds like some serious blow by. Do a compression test and a leakdown test to find out how the motor is really doping and get back to us.
Old Feb 25, 2011 | 05:20 AM
Xjtim's Avatar
Thanks man! I did a compression test when I parked it. Got 149 153 150 and 145...so good compression. Can the oil rings go out by themselves? Kinda weird situation lol.
Old Feb 25, 2011 | 09:45 AM
your numbers are on the low end for the fsm. Looking at 142-171psi from the fsm so you're still in spec. Are you using a lighter weight oil? Also could the build up in the exhaust caused this? You have a couple options here. Either figure out the problem (most likely blow by) and fix it (rebuild) Or just say screw it, pull the motor, rebuild it and have the confidence it is running right for the next 200,000 miles. You're Already half way past a rebuild with your head the bottom end would be the next step.
Old Feb 25, 2011 | 10:26 AM
Xjtim's Avatar
I'm thinking a rebuild is in order anyways...i have the jeep as a DD, but I love my Toyota...seeing as gas is sky rocketing, the yota looks better and better everyday lol. I'll update when I start the rebuild and post my findings...thanks for you help!
Old Feb 27, 2011 | 01:03 PM
Xjtim's Avatar
So update...I got truck fired up for the first time in 3yrs...found out my clutch doesn't work, master was empty, maybe it need to be bled? I was able to coast out the drive way and drive it around the block. It has a miss at like 1500-2000 rpm, after that it cleans up. It blows smoke everywhere....I have to drive it to my house and pull the engine to rebuild it.
Old Mar 1, 2011 | 04:55 AM
GeeVee's Avatar
Should be worth it to rebuild. GL
Old Mar 1, 2011 | 09:08 AM
Rbinder88's Avatar
have you tried re adjusting the valves?
Old Mar 2, 2011 | 07:11 AM
Xjtim's Avatar
Haven't tried readjusting the valves yet...I know that wouldn't help the smoke much, but maybe the missing right? Ill have to try that next, thanks for the hint...
kgcwb44
Jan 29, 2023 10:02 AM
cars-guy
Aug 16, 2020 06:59 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
dumpster84
Apr 30, 2016 06:03 AM
Coreyr384
Jul 10, 2015 11:13 AM
