'85 No Power in 4th or 5th
Old Feb 19, 2011 | 04:06 PM
jojogreen222's Avatar
I have a 85 pickup with about 165k miles on it. It has some trouble going up hills in fourth or fifth gear on the freeway. I have changed the spark plugs and wires, and the fuel filter. Compression check is not way out of normal. What are some other reasons for not having any power? Not sure if it is related, but my truck also burns oil.
Old Feb 19, 2011 | 05:06 PM
toyota4x4907's Avatar
22r or 22re?
What size tires?
Old Feb 19, 2011 | 05:09 PM
it is a 22re with 31" tires.
Old Feb 19, 2011 | 06:13 PM
nightstalker's Avatar
It may sound dumb, are yoluj sure you have the right plugs and tjhier gapped properly? I have found the gap makes a huge diff.
Old Feb 19, 2011 | 06:19 PM
RickP's Avatar
Sounds like your piston rings are worn. With oil escaping past the rings, your loosing some of the power created in the cylinder. Your approaching 200,000, I'd guess time for a rebuild. It could also be as simple as a catalytic converter or muffler plugging as those will also cause power loss. With the burning oil problem, I'm still going to have to go with rings, she's tired.
Old Feb 19, 2011 | 07:14 PM
yotakeith's Avatar
wore out motor. these trucks dont have alot of grunt in 4th or 5th gear any way. but burning oil? i agree with rick
Old Feb 27, 2011 | 03:50 PM
That's what I was afraid of. Maybe I should try and sell it to someone who wants to turn it into more of an offroad rig instead of a daily driver?
Old Feb 28, 2011 | 07:38 PM
windedwalrus's Avatar
Instead of starting a new thread i thought i'd jump on this one if it's alright. I'm having the same problem with my truck. took it out this weekend and as the day went on it lost power. it still has plenty of low end power but now it won't pull past 3000 rpm under a load. it revs fine in nutral but going down the road 3000 rpm is all it will give me, any ideas. the plugs are fine and it's not burning oil. oh and its an 88 22re with only 80000 on it. thanks.
Old Feb 28, 2011 | 07:52 PM
James Woods's Avatar
Your problem sounds alot like a restricted exhaust, check the cat make sure there is no rattle coming from it and that it flows freely, maybe remove the O2 sensor and drive it around the block and see if it changes.
Old Mar 1, 2011 | 10:04 AM
that's what i was thinking too but it hasn't put off that rotten egg sulfer smell and the converter is only about a year old
Old Mar 2, 2011 | 03:19 PM
well it wasn't the exhaust. found the fuel filter to be full of gunk. thanks for the tip Mr. Woods
smthwsn357
May 1, 2024 07:28 AM
tobylab
Dec 3, 2015 08:41 PM
shisha1999
Sep 21, 2015 08:22 PM
toofly1999
Jul 25, 2015 07:09 PM
msane99
Jul 17, 2015 10:13 AM
