Installing a "mild" cam
Old Jan 28, 2011 | 02:02 PM
LSD Rob's Avatar
Question Installing a "mild" cam
I just picked up a camshaft for the ole' truck today. I have a question upon after install about the valve lash, the guy told me for the intake side to be set at 7 thousands and exhaust at 8 thousands, now to me that seems a little tight and that is for when the engine is warm. So my question is what to set the valve lash at when I first get the sucker in there when the engine is cold?
cam specs are: 261° duration, .410" valve lift
Thanks in advance
Robert
Old Jan 28, 2011 | 02:08 PM
Outsane's Avatar
Do you know who made the cam?
you could ask them for confirmation
Old Jan 28, 2011 | 02:47 PM
fierohink's Avatar
I run one of EB's cams and I still run stock valve lash.
Old Jan 28, 2011 | 02:56 PM
LSD Rob's Avatar
did you set up the stock valve lash with the engine cold and for "break in"?
Old Jan 28, 2011 | 03:10 PM
fierohink's Avatar
What's this break-in you speak of???
Um, I installed the cam, set the lash cold to OE stock specs, and put 100k miles on it with adjustments every January.
That might not be the best method of break-in, but it worked for me.
Old Jan 28, 2011 | 03:13 PM
LSD Rob's Avatar
WEll thank you fierohink. Everyones advice is always appricated!
Old Jan 28, 2011 | 03:16 PM
fierohink's Avatar
Just use some assembly lube when you put it together and you'll be fine.
Old Jan 28, 2011 | 03:20 PM
fierohink's Avatar
Are you doing a head gasket now as well? You have to take the valve train out to get to the cam caps, I know you can usually get away with this without pulling the head and replacing the head gasket but just keep that in mind.
Old Jan 28, 2011 | 03:21 PM
LSD Rob's Avatar
Planned on the assembly lube. Not my first time installing a cam just first time with a brand new one and first time on a toyota engine. Hopefully just as easy as a Honda LOL
Old Jan 28, 2011 | 03:22 PM
LSD Rob's Avatar
No my head gasket is fine. Has a newer japer engine installed with less than 40k miles
Old Jan 28, 2011 | 03:53 PM
fierohink's Avatar
It has been my experience with diesel motors, I do a lot of hop-up work on 7.3l powerstrokes, that the more miles on the motor the less likely the head gasket is to go after pulling the head bolts. More heat cycles equals a stronger bound between head gasket and block.
Old Jan 28, 2011 | 03:56 PM
waynesworld's Avatar
Old Jan 28, 2011 | 03:57 PM
LSD Rob's Avatar
That makes perfect sense to me. If the gasket goes I'll replace it then. Speaking of 7.3's where would I be able to find a cam for one? My buddy is going to be doing quite a bit of work to his but hasn't been able to find a cam yet.
Old Jan 28, 2011 | 04:20 PM
fierohink's Avatar
There really isn't a need to replace the cam. Diesels don't really work the gassers do, especially the PSD. Basically you need to find out what your friend wants and how much he wants to spend. I have a DD that gets 16-18mpg and pulls around 530ftlbs and maybe just under 1k hp all on pump diesel. That of course was after injectors, big turbo, aftermarket engine management, high po HPOP, high fuel fuel pump, and still all stock internals.
PM me if you want some good reading.
bigjstang
Jun 2, 2025 03:56 PM
RatOmeter
Oct 22, 2015 03:17 PM
nonstop
7
Aug 11, 2015 09:26 AM
daddio
Aug 9, 2015 07:17 PM
Fakayayou
Aug 9, 2015 12:47 AM
