Transfer case with electronic speedometer setup swapped into mechanical speedo truck?
I swapped a 1993 transmission into my 1990 pickup. The transfer case on the new transmission has the electronic vehicle speed sensor on it. My truck has a mechanical speedometer cable. Eventually I want to swap in an electrical speedometer cable and a different gauge cluster, but in the meantime, what's the best way to get my speedometer hooked back up?
Can I swap the speed output parts from old transfer case to the new one?
@ goat, what is the best way to keep the speedometer cable for the stock gauge and getting the proper vss signal for the a340f trans and computer going in my 88 xtra cab with the stock gear drive transfer case. any ideas?
YotaGreenhorn
Jun 27, 2015 07:00 AM
