Transfer case with electronic speedometer setup swapped into mechanical speedo truck?
Old Jan 12, 2011 | 09:31 AM
wilshire's Avatar
I swapped a 1993 transmission into my 1990 pickup. The transfer case on the new transmission has the electronic vehicle speed sensor on it. My truck has a mechanical speedometer cable. Eventually I want to swap in an electrical speedometer cable and a different gauge cluster, but in the meantime, what's the best way to get my speedometer hooked back up?
Can I swap the speed output parts from old transfer case to the new one?
Old Feb 28, 2012 | 01:45 PM
BlindfoldMemphis's Avatar
Did you ever figure it out?
What did you end up doing?
Old Feb 28, 2012 | 02:09 PM
mt_goat's Avatar
You can just swap the speed sensors to match your cable or wiring and dash cluster. The part the goes into the transfer case is the same on both (except there are different gear ratios). Only the outside is different between the 2.
Old Feb 28, 2012 | 02:46 PM
donomite49's Avatar
@ goat, what is the best way to keep the speedometer cable for the stock gauge and getting the proper vss signal for the a340f trans and computer going in my 88 xtra cab with the stock gear drive transfer case. any ideas?
Old Feb 28, 2012 | 04:29 PM
mt_goat's Avatar
I'm not sure on that one.
Old Feb 29, 2012 | 02:39 AM
wilshire's Avatar
BlindfoldMemphis - I ended up doing MrGoat's suggestion and swapping the sensors. It was a breeze.
Old Feb 29, 2012 | 02:45 AM
racerflea's Avatar
Could that work when converting to a th350 trans??
Old Aug 15, 2013 | 09:43 AM
Bumpin' Yota's Avatar
Red face
Likewise! Id definitely like to know!
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
YotaGreenhorn
Jun 27, 2015 07:00 AM
P51warrior
Jun 25, 2015 05:50 AM
ACZR
Jun 23, 2015 07:55 PM
