new gauge cluster, goofy rpm?
Old Dec 14, 2010 | 10:52 PM
hiltu's Avatar
I upgraded from the stock cluster in my dlx 4runner to a SR5 with tach. I was suprised to see i never go above 3000rpm. My belt will squeek/slip when i go above that and the engine feels like its reving a whole lot higher. If i had purchased a V6 gauge cluster for my 22re would my rpms indicate lower than actual? im running 33's with 5.29 gears, so if someone running the same setup could give me some reference of speed and gear vs. rpm to see if the tach is registering right, that would be best. Thanks
Old Dec 14, 2010 | 11:13 PM
peow130's Avatar
gears and tire size don't matter to the tach..
If you purchased an SR5 cluster from a V6 rig, then you'd have a problem like this.
Theres a fix on here if you search.
Old Dec 15, 2010 | 02:51 PM
Uthro69's Avatar
lol problem there is the tach is set up for a v6.. your a Inline 4 cylinder.
Old Dec 15, 2010 | 04:52 PM
hiltu's Avatar
uthro69, your telling me thats my problem or guessing it is?
Is there any marking on the cluster that would indicate wether its a V6 or I4 cluster. The guy i bought it off of "said" it came from a 22re.... can someone give me reference for what rpms to expect in 5th gear? im going off of memory but it was looking like 35mph was 1000ish and 75 mph was 2300.
Old Dec 15, 2010 | 06:13 PM
Uthro69's Avatar
sounds about right, but in a way to reply both, if its from a v6 then its gonna be out of wack, im not sure if there is a way to indicate whether its a 6 or a 4
Old Dec 15, 2010 | 07:09 PM
herpestes's Avatar
check the back of the gauge set, thinking that the 6 cyclinder should show this
and 4 cyclinder should show
Old Jan 12, 2011 | 08:56 PM
hiltu's Avatar
I been reading about the potentiometer mod. Some questions arise. First, it seems that a pot is used when the cluster was meant for less cylinders than the engine has (i.e. V6 cluster for a V8 motor, or 22re cluster for a V6). Does this work the other way, as in can i correct my tachometer from a V6 for my 22re? Next question, is there an onboard potentiometer or do I have to buy one? If its dependant on year, how can I tell? (guy i bought the gauge cluster from said its for a 4 cylinder, but its for a V6 so there is no way telling what year it is from based on what he said. Thanks in advance.
Old Jan 12, 2011 | 09:43 PM
DeathCougar's Avatar
You can also take off the clear face and black fascia, and it will say V6 on the face of the gauge in the corner of the tach
Old Jan 13, 2011 | 09:33 AM
hiltu's Avatar
when i pull it apart to either adjust or add the pot i will check it. Do you know if there is an adjustable potentiometer on the cluster?
Old Jan 14, 2011 | 10:43 AM
herpestes's Avatar
don't know if this will help but check the last post on bottom for links
http://board.marlincrawler.com/index...highlight=tach
Old Jan 14, 2011 | 09:14 PM
hiltu's Avatar
thanks herpestes. that helps alot. My next question is something i've struggled to find, a chart comparing speed in a gear and the corresponding RPM. Using a calculator and other info i found i believe these to be accurate:
1st gear 10mph = 1911rpm
1st gear 15mph = 2867rpm
2nd gear 20mph = 2070rpm
3rd gear 30mph = 2007rpm
4th gear 45mph = 2175rpm
5th gear 60mph = 2465rpm
5th gear 70mph = 2876rpm
if someone could please confirm or correct me that would be awesome.... getting closer everyday to having an accurate tach.
Old Jan 14, 2011 | 10:19 PM
herpestes's Avatar
hiltu
does the tach face that you are trying to correct have the checker board pattern?
Old Jan 15, 2011 | 07:27 AM
hiltu's Avatar
Originally Posted by herpestes
hiltu
no checkerboard, just horizontal lines going through the backdrop.
Old Jan 17, 2011 | 10:12 PM
hiltu's Avatar
herpestes, is it bad to have the horizontal lines and not checkerboard?
Old Jan 25, 2011 | 05:21 PM
hiltu's Avatar
bump for more information, guidance. I know people can take a V6 cluster to a V8 and add a potentiometer and make it right. What about a V6 cluster to the 22re, how would that be "fixed"?
Old Jan 25, 2011 | 11:03 PM
herpestes's Avatar
no.......just that i had a spare gauge set that has the checker board pattern that came from a 4 banger. if you remove the speedo from the gauge set you will see the potentiometer from the side. the potentiometer should be white in color and have the phillips screw head. take a tune up tach and start up your engine and use that to adjust the factory tach.
Old Jan 25, 2011 | 11:26 PM
scuba's Avatar
http://www.grimmjeeper.com/gears.html
Put in the vehicle info and it will tell you what rpms the engine will be at while traveling a certain speed.
mussy01
Dec 13, 2016 08:20 PM
gary4runner
Sep 24, 2015 12:53 AM
highonpottery
Aug 25, 2015 03:45 PM
O Holy P
Aug 18, 2015 02:33 PM
mund1011
Aug 16, 2015 07:10 AM
