Breaking the lock on my cam bolt
Howdy, I'm trying to get my cam bolt off to do an H/G replacement. Can't seem to get it, but a big part of that is keeping the cam from turning. I've tried wrapping some steel wires around it (broke a few wrapped together), but I'm worried about hurting the chain/cam. I've sprayed some Pb blaster on, we'll see what happens.
What's the proper way to "lock" the cam to remove the cam bolt? Or, what's the proper way that doesn't require an SST ;-)
Bout' the only way your gonna break those bolts lose (assuming it's the 3.0) is with an impact wrench, unless u have a an sst or can fab one up yourself. I did that job a year ago on my 95' and had to stop there because of the cams. Others have had good luck with jamming some sort of wedge between the gears and the block but i didn't like that very much. I would be most concerned with damaging the teeth on there. The impact takes em' right off, hope that helps
This is a 22re btw.
-Seth
pyramid
Jul 30, 2015 10:05 AM
