? rust HOLES repair, cab
wanting to get ideas on how to repair this rust bucket
missing cab corners and rockers, and much more
the cab mount by the right door is useless. the door is sagging down, and must be pushed up, and the rear pillar pushed in to close the door
the floor insulation came off easily in large chunks with a hammer and chisel.
I do have a welder and a donor xtracab
I think you would be better off doing a cab swap instead of trying to repair that rust, if it was just a few small rust holes then it would be worth it, but that cab has major structural damage and isn`t worth trying to fix.
I have a good cab with one rust hole that you can have. But you need to pay for freight to ship it. I need to get it out of the yard. The cab is stripped to the shell only. Just let me know. I am on the coast in NC.
Later
Later
anybody need parts off it?
I'm going to scrap it out
not worth fixing
will use parts from it to repair the xtracab
only making a temporary patch to keep some snow out this winter while it sits till spring
not worth fixing
i had this problem on my 4runner and ground away the rust and wire wheeled it and then use the foam to feel gaps and pop riveted some sheet metal in place and used the foam to fill the gaps and used rubber undercoating on the back side. i did that a year or 2 ago. seems to be holding up alright.
