120v On Board Air using an inverter
I have an inverter that is rated for 400w(800w peak), has anyone ever considered using a small 120v air compressor (like a nailer size) on their rig for on board air? I want to use air tools, i realize this isn't a big enough compressor for some tools, but it will run an impact(not to it's max of course).
Seems you can pick up a decent used one for cheap. I figured i would separate the motor/pump from the tank, relocate those two pieces.
I tried searching but all i get is 12v OBA.
thanks
thanks
No i havent tried, my father has one i was going to use a s a test. I'm guessing the start up draw is going to be more then the inverter can handle. The compressor claims to only draw 260w.
sorry, i should mention that the inverter is installed in a truck that is not running at the moment(nor tagged), oh, and the inverter isn't actually connected to the battery yet.....i'm just thinking out loud.
thanks
compressor claims 260watts, i will edit the above...mistake....amps...watts...they are the same right?...haha!
thanks
I was thinking the same thing, I have a 400w inverter that i use to power my small round compressor that i got from HF for like 39 bucks, it works fine but needs a bigger tank, I have a larger inverter that I was thinking on installing in the rig and hooking to the compressor if i mount it somewhere in the rig. not sure what to do yet...to many choices.
Watt=P, Current is Amps=IOHM's Law:
Ohm's Law defines the relationships between (P) power, (E) voltage, (I) current, and (R) resistance. One ohm is the resistance value through which one volt will maintain a current of one ampere.
( I ) Current is what flows on a wire or conductor like water flowing down a river. Current flows from negative to positive on the surface of a conductor. Current is measured in (A) amperes or amps.
( E ) or V for volts Voltage is the difference in electrical potential between two points in a circuit. It's the push or pressure behind current flow through a circuit, and is measured in (V) volts.
( R ) Resistance determines how much current will flow through a component. Resistors are used to control voltage and current levels. A very high resistance allows a small amount of current to flow. A very low resistance allows a large amount of current to flow. Resistance is measured in ohms.
( P ) Power is the amount of current times the voltage level at a given point measured in wattage or watts
ohms law calculator link:
http://www.the12volt.com/ohm/page2.asp
source for this stuff below:
Calculate for Voltage (E)
E = I x R
E = P / I
E = Square Root of (P x R)
Calculate for Resistance (R)
R = P / I ^2
R = E / I
R = E^ 2 / P
Calculate for Power (P)
P = I ^2 x R
P = E x I
P = E ^2 / R
Calculate for Current (I)
I = P / E
I = Square Root of (P / R)
I = E / R
I love YT. Just wait a week or less and your question will come up without even asking it.
I got a free pancake aircompressor from my boss, and can score an inverter for cheap. Poormans OBA! I will keep an eye on this thread for even more ideas.
nope here: edumacate yourself
OHM's Law:
E = I x R
E = P / I
R = P / I ^2
R = E / I
R = E^ 2 / P
P = I ^2 x R
P = E x I
P = E ^2 / R
I = P / E
I = E / R
E = I x R
E = P / I
R = P / I ^2
R = E / I
R = E^ 2 / P
P = I ^2 x R
P = E x I
P = E ^2 / R
I = P / E
I = E / R
The compressor is a good idea, subscribed to see if it works.
Since I jet fired the truck up last night, I'll have to swing by my father's house and test his compressor. I am thinking I can mount the comp(sans tank) in the bed wall behind the seat. It will be loud in the truck but out of the elements.
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Esibnitsud
Jul 30, 2015 08:19 PM
skoti89
Jul 8, 2015 12:05 AM
