Oil in ac vents
The only leak I am aware of is the rear main seal and the valve cover gasket. The valve cover gasket was just replaced a month or two ago. The darn thing is leaking again. As far as the evaporator goes, I pretty much stripped the whole interior to run power, rca, and speaker wires. I didn't notice anything odd, visually nor anything that smelled like oil from under there. The AC vents are covered with a film of oil. The odor gets worse the further I drive or the harder the car has to work. The timing belt, front cam seals, crankshaft seals were all replaced when the valve cover gasket was done. All the upper plenum gaskets and throttle body gaskets were also replaced.
I'm not sure about oil in the vents but I currently have a very small leak in the back of my passenger side valve cover. Unfortunately that is right above the damn crossover pipe and I do get a pretty strong burnt oil smell in the cab sometimes.
TJWilly
Jul 31, 2015 02:05 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
