How to drop oil pan on a '90 v6 4runner
Old Sep 19, 2010 | 02:42 PM
Crimson Yota's Avatar
Unhappy How to drop oil pan on a '90 v6 4runner
Hey I need to drop the oil pan on my Automatic 1990 V6 4WD 4Runner.
I'm wondering how you do this?
I have the book but that only tells how to on a 2WD, and after searching for a good 15 minutes I could only find how to's on 2WD and 22RE models.
Any help would be greatly appreciated!
Thanks
Old Sep 19, 2010 | 02:45 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Drop the diff...
I don't think it's as hard to do as ppl make out...
There's just 3 mounts for the diff...
You could just drop it, joints and all... Or remove the shaft, joints and diff completely from the truck...
To save time, remove the front drive shaft from the diff and wire it to the frame with a coat hanger, bungee or strap...
I.e, not the whole shaft, just half.
Old Sep 19, 2010 | 02:51 PM
Does anyone on YotaTech see why Crimson can't just remove the CV axle bolts (that are behind the drive flanges or hubs), the front drive shaft at the diff, remove the two upper frame mounts, then with the front diff supported by a jack, remove the 4 bolts that hold the front x member and diff mount and lower the entire front diff and shafts out all at one time?
Old Sep 19, 2010 | 02:53 PM
Alright thanks alot. Doesn't sound too hard.
Old Sep 19, 2010 | 03:20 PM
92 TOY's Avatar
it's not that hard......
in "Thread B" in my sig, i have a whole section about doing this.
RDubya
Feb 10, 2017 04:46 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
alexcarey
Oct 14, 2015 06:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
viesail
Sep 21, 2015 06:00 AM
