92 4x4 truck swaying issues
I have a 92 4x4 basic with a 5inch rough country lift. I have gone through the entire suspension system and replaced everything that showed wear. I had the stock rear springs rebushed and the front a arms bushed. I replaced all the ball joints and the outside tierod ends on both sides. I have brand new Mickey Thompson Baja MTZ`S 33 12.5 15 `s on aluminum wheels. I had them balanced and have checked the tire pressure.
The problem:
While at high speeds when the truck hits a bump it is downright scary how much it pitches and wanders. My steering has about 2 inches of dead steer in the wheel, meaning that from dead strait to turn the wheels there is a dead spot before the wheel turns. I wouldnt even say it doesnt turn, more that it requires alot more input to get them to turn.
One thing I did notice when I was redoing the front end was that the swaybar was very rusty under the bushings. After sand blasting the rust away the swaybar wasnt very snug to the bushings. Plus I replaced the swaybar links with a set from energy suspension, but they were a set for "all trucks"
My question is can the jumping around be caused by the swaybar being incorrectly installed/not fitted to the bushings snugg? Or perhaps the links didnt tighten up enough?
The problem:
You probably would barely even notice if you took the sway bar off
Go back through everything and find why you have slop in the steering wheel, that is most likey your problem. May as well check the steering stabalizer while your at it.
I am stumped. only thing left as you said is the steering box....
Dharris1986
28
Apr 17, 2017 03:34 PM
voiddweller
19
May 2, 2016 09:10 PM
I was hoping it was a common issue that didnt require me to take apart the steering again. Although the local PAP has a tilt wheel I am thinking of grabbing for my truck. but it is gray and mine is blue : /
