1jz '88
1jz '88
So my truck has the 3.0 v6 with the 5spd and i'm lookin at swappin to a different/better motor. I also can get a g58 with tcase if need be. I'm considering doing either an N/A 2jz or 1jzgte. Will i be able to directly bolt either of those engines up to either of those transmissions...or if i is there a company that makes a bellhousing that would allow me to bolt one of those 2 transmissions up to those two engines?
get a bell housing for a 2jzge 5spd.
they use a w56 trans in the lexus is300 and in the mkiv supra behind the 2jzge motor. you can purchase the bell housing new for about 350 bucks. you will also need to run the clutch and fly wheel through out bearing from the jz motor..
motor mounts might have to be custom. i haven't searched that route.. but for the 7m motor i used factory parts to install. very tight install for the inline six but definitely do able.
The 1j and 2j also used the r154 transmission. The r154 has the proper bell housing to bolt to any "R" series transmission, but the input shaft of the r154 is longer than your r150f. The later r150f trannies have an input shaft almost as long as the r154, you will need one of those.
I chose the custom bell housing route because it was much less labor intensive and much less expensive. Check out my thread on my 1JZ swap. Ill be dropping the motor in this weekend hopefully and should be able to answer more questions on the swap.
It would be fourth gear isnt the same ratio if any thing ',first gear is next to the intermediate plate with 5ththe on the other side..
I do remember the article i read the guy swaped most of the parts. Do you have a link to that thread/article?
I'm looking for the article now as curiosity has gotten the best of me.
Here are the gear ratios though...
R150 gearing:
1st: 3.830
2nd: 2.062
3rd: 1.436
4th: 1.000
5th: 0.838
Reverse: 4.220
R154 Gearing:
1st: 3.251
2nd: 1.955
3rd: 1.310
4th: 1.00
5th: 0.753
Reverse: 3.18
Edit: Found it!
http://www.pirate4x4.com/forum/archi.../t-918808.html
R150 gearing:
1st: 3.830
2nd: 2.062
3rd: 1.436
4th: 1.000
5th: 0.838
Reverse: 4.220
R154 Gearing:
1st: 3.251
2nd: 1.955
3rd: 1.310
4th: 1.00
5th: 0.753
Reverse: 3.18
Edit: Found it!
suppra87
All Other Toyota Swaps
43
Feb 6, 2018 06:57 PM
great info
