sweet noise starting at 55 on when accelerating
When I'm driving at 45 and up (approximately) I get this vibration in the truck and a resonating sound in the cab. It sounds like it coming from the back end. It only is there if I've got the gas down, but if I let it off or decelerate then it goes away and there is just normal road noise. There is full oil in the rear diff and it doesn't leak (75w-90 Redline). It only does it at the higher speed and you can't feel anything in the steering wheel and it definitely doesn't seem like it's coming from directly underneath me, but from the back of the truck.
Any ideas?
Any ideas?
Might be the pinion angle is a little too high:
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
Under load, the pinion will naturally tilt upwards and that may be pushing it into a slight vibration. Backing off the gas lets the pinion tilt back down and run smooth.
The backlash sounds kinda good b/c sometimes if I don't let off the clutch real smooth i get a small "clank". Correct me if I'm wrong or don't know what I'm talking about, but it could be tied into the vibrations.
Yes there are vibrations coming from the back end somewhere.
Yes, it just drives like a front wheel car. Steering feels funny, so be carefull. let us know what you find. Make sure it is in Hi, not low range. Yeah i know you knew better, but I had to make sure to say it, because some moron would ask
Steezy96yota
Jul 6, 2015 10:00 AM
