power steering hose - pump to reservoir
Hey fella's, I noticed the other day that I've got a hose that looks like it's about to let loose; it's swelling, and starting to seep a little...
It's the fluid return hose coming from the pump and up to the reservoir; the big one that's like 1/2" in diameter.
Anyone ever been able to get one outside of the dealership?
I know the dealer's probably going to be the best one I can get, but geez, $40 for that little 1ft long hose with 2 curves in it? comon...
Bad idea. Heater hose is not designed for use with oil, (ATF) which will bloat the heater hose and eventually leak again- likely much more quickly than the OEM hose went.
It has to be a hose designed for use with oil, not just any hose.
Did you notice the price of the pressure hose? 369.06! bought one about ten years ago for 15$ from checker and its worked great. It's still on the vehicle. If you can get the pressure hose after market, someone will carry a replacement for the return line.
yeah I put a replacement pressure hose on it when I did the motor; it had actually split and was dripping down onto the frame
and yeah I know that heater hose wont work
I've seen people use that for trans cooler lines before... didn't last a week, LMAO
I'm going to call the local dealer tomorrow and see what their cost is; I just looked this up and seen that price...
I REALLY want to get it replaced ASAP before it bursts and sprays ATF all over my hot header
I've seen people use that for trans cooler lines before... didn't last a week, LMAOI'm going to call the local dealer tomorrow and see what their cost is; I just looked this up and seen that price...
So it's the hose that supplies fluid to the pump? It's not under any significant pressure so using an appropriately rated hose should be fine.
The only one that sees high pressure is the one from the pump to the steering box.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
jon.r
Jul 11, 2015 03:34 PM
Poncho0206
Jul 10, 2015 06:21 PM
skoti89
Jul 8, 2015 12:05 AM
