Sponsored by: CARiD
bed pushed into cab
Old Dec 21, 2009 | 10:34 PM
85yota4x4's Avatar
bed pushed into cab
maintenace and repair thread wouldnt allow mw t post, but anyways the bed of my truck is pushed into my cab, because i had a quad in the bed of my truck that wasnt tied dow, and when i hit my brakes it went into the cab, and pushed the bed of the truck into the cab, so is there any way that i can push the bed back, so it isnt against the cab without pulling the bed completely off?
Old Dec 21, 2009 | 10:51 PM
81 yota 4x4's Avatar
theres only 6 bolts holding the bed in, beside that is just the wiring for the tail lights and the gas filler
its not worth trying to work around it, just pull the bed off. its really not hard at all
Old Dec 21, 2009 | 10:59 PM
85yota4x4's Avatar
yeah but i am trying to work around lettingmy parents knowing that this happened so that is why i wanted to avoid that
Old Dec 21, 2009 | 11:03 PM
1GenCrawler's Avatar
not sure about what your bed is like but could you hook ratchet straps to it and pull it back?
Old Dec 21, 2009 | 11:11 PM
85yota4x4's Avatar
i might i will try tomorrow
Old Dec 21, 2009 | 11:20 PM
lmao hahahahaha well in that case yeah id say ratchet strap would be the best, but it aint gonna be perfect
Old Dec 21, 2009 | 11:52 PM
not perfect but a little less noticable.
Old Dec 22, 2009 | 12:00 AM
85yota4x4's Avatar
i dont need it to be perfect i just dont want it to rub against the cab
Old Dec 22, 2009 | 12:33 AM
then that'll work
Old Dec 22, 2009 | 07:25 AM
MaK92-4RnR's Avatar
Not sure why you put a quad in the back of your truck unstrapped... could've gone through your window. but just take it off, examine it and do whats needed. I dont really expect ratchet straps to "straighten" it at all...
Old Dec 22, 2009 | 07:37 AM
dropzone's Avatar
Fossilized
Ratchet straps might not be quite strong enough....sounds like you need to buy some anyway to secure the quad.
make sure you attachment point is good (which might be hard since the bed is bent up against the cab)...maybe put a coat over it incase it comes loose under tension...just like you do on a winch cable under tension.
Old Dec 22, 2009 | 10:47 AM
why at least wasnt the park brake on? or in gear? the ratchet strap, as stated before, isnt going to make it perfect but should pull it away from the cab enough for you. May need a heavy duty one.
Old Dec 22, 2009 | 11:00 AM
4Crawler's Avatar
Probably just need to loosen the 8 bed bolts and then get someone on the other side of the bed to help lift and slide it back a little. Not that hard to do. Be sure to snug the bolts back down after wards, likely they were loose to begin with and that is what let it slide forward.
Old Dec 22, 2009 | 11:05 AM
85yota4x4's Avatar
it was in gear and parking brake on but i hit a dip going to fast and pushed the quad forward
88sasturbotoy
Jan 30, 2026 01:57 PM
young buck
18
Aug 27, 2018 02:40 PM
Backcountry411
Jul 24, 2015 08:06 AM
elwood73
Jul 5, 2015 07:07 AM
