Stock flywheel weight?
Old Nov 14, 2009 | 10:57 AM
Enzo1089's Avatar
Hey guys, what is the weight of a stock flywheel off a 22re? Tried searching but couldnt find it. Thanks!
Old Nov 14, 2009 | 11:03 AM
flyingbrass's Avatar
I weighed mine using my bathroom scales. 24 lbs.
Old Nov 14, 2009 | 11:15 AM
Targetnut's Avatar
I weighed mine with fishing scales, 24lbs too.
That was before i shaved 10lbs off....
Old Nov 16, 2009 | 01:17 PM
Enzo1089's Avatar
How did you go about shaving off 10lbs?
Old Nov 16, 2009 | 03:09 PM
Enzo1089's Avatar
Yeah we were looking to go lighter, but dont want to go to light, so that might be perfect.
Old Nov 17, 2009 | 04:26 AM
jimep's Avatar
one of my buddies had a machine shop drill the whole way around the outside edge of his flywheel off the clutch contact surface to lighten it up. Make sure they have the capability to balance it too... lighter does rev quicker!
Old Nov 17, 2009 | 04:33 PM
Targetnut's Avatar
It wasn't easy,,,,or pretty.
First I turned the backside with a brake lathe. That was about 5lbs
Then I use a drill and a die grinder to cut out the spaces between the clutch mounting holes.
I made an adapter and balanced it on a wheel balancer.
And it is remarkable how much it improved responsiveness. I'ts didn't make it into an instant drag car but it was a very noticeable improvement.
smithyboy69
Nov 28, 2015 04:13 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
RobotMoose
Sep 2, 2015 05:53 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
TransAmBandit
Jul 28, 2015 11:30 PM
