Throwout Bearing Removal
I am right in the middle of a clutch swap and have searched through more then a few guides and walkthroughs and haven't found anything about the throwout bearing.
I pulled the fork clip away from the top bottom and side but cant pull it out. Does the whole part from the fork forward slide off the spindle or do you have to separate the bearing. How much pressure do you need to pull on it with?
P.S. Thanks to everyone that has posted in the past about clutch replacements, the pictures and tips that I read were a godsend.
-1991 Hillux 4x4 with 22re
I'm doing my second clutch but off hand I can't remember how it comes off but I can take some pictures when I get home tonight, if anyone doesn't help you out first.
Here is the link to my first replacement on an 86 Truck
https://www.yotatech.com/forums/f116...ke-2-a-177863/
yeah on mine there was a bearing pressed into a sleave dealy that attached onto the clutch fork, you have to get the bearing pressed off and a new one pressed on, i had a guy at a local shop do it for 10 bucks, but yeah everything attached to the bearing should slide right off..?
he's gone
7
Dec 3, 2019 07:08 AM
Sep 4, 2015 09:27 AM
