93 runner grille help
Old Sep 26, 2009 | 10:47 AM
jortiz2110's Avatar
I know this sounds stupid, but I need some help getting my grille of. I found 10 clips and the corner lamps holding it on (6 on top and 2 under headlamps and another 2 bottome of grille) I released them all and the grille just wont come off it seems as if something else is still holding it in place. Anyone have this same setup please let me know what I am missing! Thanks!!
Old Sep 26, 2009 | 11:34 AM
James Dean's Avatar
There are 11 (6 top, 3 lower middle, 2 under marker lights). 1 in the middle lower, is the one I think your missing.
Old Sep 27, 2009 | 01:23 PM
jortiz2110's Avatar
ahh I will look into it and let you know thanks alot for your help!
Old Sep 29, 2009 | 07:55 PM
jortiz2110's Avatar
ok so I got all 11 and the corners off but it is still held up. I am thinking the brakets from the headlamps are the issue, thoughts?
Old Sep 29, 2009 | 08:14 PM
James Dean's Avatar
I not positive but I think the side marker lights have to be out.
Old Sep 29, 2009 | 08:18 PM
jortiz2110's Avatar
yea those are out. But I am thinking of taking the actual headlamp assy behind the grille (3bolts) to see if that works
Old Sep 29, 2009 | 08:22 PM
James Dean's Avatar
The edge of the grill has tabs that hook into the side marker lights. Let me know if this doesn't help. I'll go pull mine to see where else it attatches.
Old Sep 29, 2009 | 08:25 PM
James Dean's Avatar
The head lights or buckets do not have to be removed.
Old Sep 29, 2009 | 08:33 PM
James Dean's Avatar
I know it's hard if your bumper is still on. There is a lip on the bottom of the grill and the two upper corners catch on the fender points over the marker lights.
Old Sep 29, 2009 | 09:33 PM
94YOTAG's Avatar
nice body work
Old Sep 30, 2009 | 07:20 PM
jortiz2110's Avatar
Talking
Ok so I finally got it off. My theory was right, I had to unbolt the headlamp assy. in order to get the extra clearance I needed. This is probably due to the bumper being dinged up by the previous owner. Sorry in advance for the low quality pictures its taken with my phone.
Heres the reason I needed it off, I needed to relocate my LED strobes behind the grille for better viewing (you'll notice the top piece of plastic is missing)
Thanks for all your help!
MMA_Alex
25
Apr 18, 2017 05:07 AM
lledwod
Aug 30, 2016 01:03 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
