Rear drive shaft bolt
Old Sep 2, 2009 | 12:31 PM
tiebor's Avatar
I am trying to change out my u-joint on the rear. The problem I am having is that one of the bolts on the flange will not loosen or tighten. Is there any way to get this out easily? This is on a 94 4wd Pickup.
Old Sep 2, 2009 | 12:52 PM
yoterr's Avatar
is it just seized? spray it with a good pentrator and brace the one wrench and pull like hell
Old Sep 2, 2009 | 12:54 PM
bugs1961's Avatar
Turn the driveshaft to a convenient angle and use the parking brake and transmission to keep the driveshaft from turning. Then use a boxed end wrench on one side to hold the bolt from turning if you need to, and put a 2' or so long piece of pipe over a breaker bar to give you good leverage while pulling on the other. Using 6-point wrenches and sockets help prevent rounding off the bolt and nut. Penetrating oil over night will help a lot also.
Old Sep 2, 2009 | 01:06 PM
tiebor's Avatar
I guess I worded that wrong. The bolt is spinning but not coming loose even though I am holding the nut from turning. Basically the bolt is spinning inside the nut and not coming loose.
Old Sep 2, 2009 | 01:14 PM
88yotasr5runner's Avatar
time for the drill or torch!
Old Sep 2, 2009 | 02:12 PM
yoterr's Avatar
sawzaw
Old Sep 2, 2009 | 09:00 PM
desertcamper67's Avatar
I doubt you have the room but if you can somehow grab ahold of either the nut or bolt head and pull as the other end is turning it might come out. Very effective with air tool speed. Small or needle nose vice grips may work if there's room.
If no room and since you have all the other bolts out you can pry a bit between the two flanges (better with a third hand) while spinning the bolt and nut apart. Its pressure pulling or pushing the bolt and nut apart while unscrewing that gets it apart.
If this doesn't work, be careful with the saw and don't accidentally cut into your yokes too much.
Good luck.
Old Sep 2, 2009 | 09:06 PM
874runnersr5's Avatar
4 1/2" angle grinder
Old Sep 2, 2009 | 09:10 PM
raydouble's Avatar
Any one of these will work.
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
TNRunner88
Jul 1, 2015 08:00 PM
Gamble_STi
Jul 1, 2015 12:51 PM
