had it with my trailgear springs
Old Aug 30, 2009 | 06:23 AM
Beaniam's Avatar
I'm on my second set of trailgear springs in the front on my sas'd pickup and now the rear sits about 2.3-3" uneven because they settled WAY different. The fronts were S'd out and flat after 4 months and the rear has settled to this point after 9 months. I take it easy on my truck I feel and I never jump it. What 5" springs should I go with... marlin? All pro? I'm ready to just ditch the rear springs and go with a different brand I'm so frustrated.
Old Aug 30, 2009 | 06:30 AM
peapicker's Avatar
well crap!
I just purchesed the tg kit, front and rear! should I send it back? Wish I hadnt read this one.
Old Aug 30, 2009 | 06:45 AM
Beaniam's Avatar
A lot of people bash TG and a lot of people swear by it. I guess I just got unlucky. I just find 2-3" of settle difference through 2 sets of springs to be unacceptable especially with how I take care of my junk.
Old Aug 30, 2009 | 06:52 AM
peapicker's Avatar
I guess Im gona put em in, worse case just buy some frome marlin! If they do go flat tg!
Old Aug 30, 2009 | 06:55 AM
yoterr's Avatar
or you could do rears up front and ford, or chevys out back....
Old Aug 30, 2009 | 07:03 AM
ScottyC's Avatar
Are you running bump stops up front? You have pics of them by chance?
I have never had an issue with the 20+ kits I have installed having that issue unless the bump stops were never installed or installed where they let the springs go into a negative arch.
Old Aug 30, 2009 | 07:18 AM
ScottyC's Avatar
Based on this pic, it looks like you are running the lower poly mount, but nothing off the frame. This is why the spring are going negative arch and bending like an S.
Old Aug 30, 2009 | 07:26 AM
Beaniam's Avatar
that was my old 4" regular springs. I figured the warn bumper and winch did those in. they always were too soft even from day one. I ran bump stops until they settled to the point where the bumpstops sat about 2" away from the frame stops. Then I cut them off because it kept bottoming out on the street. The 5"hd I've had in the front for a couple months now have had no issues so far. the back 4" springs are settled 3" more on the driver side however. I have no frame stops on the rear. The tires stuff in the fender before those springs flatten.
Old Aug 30, 2009 | 08:01 PM
ScottyC's Avatar
I guess the original post is confusing then.
Which ones are you having issue with? Front, rear, both???
Old Aug 30, 2009 | 08:05 PM
camo31_10.50's Avatar
ALCAN!!!!
i've never heard ANYTHING bad about them..
i've also heard that marlin has some great springs...
Old Aug 30, 2009 | 08:10 PM
Issues's Avatar
I went with Allpro springs on my 89 myself. And Ive had no problems what so ever, (2yrs)... (knock on wood, lol)
Old Aug 30, 2009 | 08:54 PM
seanmearse's Avatar
That thing is beautiful.
But on another note, I love the pro comp springs I bought for the 84, I do run them hard, and so far no issues. I go wheeling pretty much every weekend. They havent even dropped, still up in the air, and they really arent that stiff. Might give them a try, see what happens. Just my .02
Old Aug 31, 2009 | 06:13 AM
Beaniam's Avatar
I had problems with my original 4" fronts which settled and flattened. I replaced them with 5"hd which are still holding up. Now my issue is with the original 4" rear which have settled about 3" more on the driver side. Whatever spring I go with in the rear I'd like to keep the same length as the trailgear so I think that limits it to the marlin's. Don't really want to cut off and weld on new hangers again. Was under the impression that TG and MC got their springs from the same supplier though.
Old Aug 31, 2009 | 11:09 AM
ScottyC's Avatar
Oh, okay.
FWIW, without an antiwrap bar, you will fatigue springs in the rear. If they are "S"ing from spring wrap, then that is your issue.
All-Pro and Marlin springs are built by Betts spring, but assembled in India. FWIW, I never had an issue with my rear 5" TG Springs. They do settle though, but that is normal.
Old Aug 31, 2009 | 02:03 PM
Beaniam's Avatar
Oh, okay.
So the marlin springs are the same but $40 more? I know they settle, I'm fine with settling but one settling 3" more than the other is unacceptable. I guess I will replace the 4" rears with 5" and hope they settle evenly. The rears haven't S'd at all, they just settled way out of whack.
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
83
Sep 27, 2015 04:13 PM
