Clunking vibration when turning?????
On my way to work, on even slight turns i was feeling and hearing a lound clunking sound, and the truck would vibrate. When i'm going straight, it's fine. It scared me, but i made it work safe
Where do i start?
Thanks
95 4x4 SR5
Where do i start?
Thanks
95 4x4 SR5
Have someone rock the steering wheel back and forth (engine running) while you or someone with a little knowledge looks at your steering linkage,bushings,ball joints,steering gear or rack for independent movenent. Something might show up shifting under the load. This is how I used to find bad parts that others couldn't.
I don't suggest driving it until you are sure it is safe. Bad CV joint is fine to drive on unless it affects your steering.
Good luck.
Good luck.
ripp96
Jul 25, 2015 02:32 PM
Hamonacracker
Jul 17, 2015 08:33 AM
