'91 22RE starter removal
Yet another problem with removal of stuff. This time I need to replace the starter. The only problem is that the starter located in a void between the intake and EFI manifold and the front differential. I would rather not remove either one, any advice? I am replacing it with a rebuilt from Toyota.
the starter is pretty easy to replace. go through the passenger's side wheel well. Its RIGHT there. You should be able to access both bolts from there if you are a contortionist, but at least one. The other one you might have to go up from the bottom, but you do NOT need to remove any of that stuff.
ZONAYODA
Jul 13, 2015 07:17 PM
