Where is timing plug to short out?
searched everywhere online to find where it is. found couple pics but dont really show where in the harness the plug is.
my 22RE engine and harness is out of a 88 4runner
If anyone has a picture of theres that would be awsome.
where it is, what it looks like
Right behind (towards the back of the truck) the main fuse panel under the hood on the passengers side inner fender. It's a little black box. Pull the top off and jumper the T1 and E (I think) terminals.
Thats the problem. this engine is put in a rock crawler so there is no locations.
if i could see where aprox the plug comes out of the wire harness i can probably find it on mine.
i dont want to short the wrong plug or something..
yea on my 91 its where junkers says it is, but on my 86 runner its on the drivers side plugged in to the fender.
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Pretty simple connectors, the O2 sensor test connector is round with 1 terminal. The timing connector is round with 2 terminals (that you connect together with the jumper) and the other round plug has 3 terminals. Hard to mix them up.
As noted on the web page above, that connector has some of the ECU O2 circuit test voltages, like the Vf signal. I think there is some mention of it in the FSM.
Not sure what you are trying to do, but the base timing not changing after installing the jumper is often due to a bad TPS adjustment:
- http://www.4crawler.com/4x4/CheapTri...roubleshooting
thats asuming that was even the right jumper connector in the first place..
was just trying to set the timing properly. i just rebuilt the whole motor.
motor runs fine so far
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
