HIDs and LEDs Installed!!
Installed a McCulloch HID kit and Led parking lights where my turn signals used to be, signals are now in the corners. All I had to do was swap connectors. Tell me what you think...
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
Night Shots
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]Night Shots
[IMG]
[/IMG][IMG]
[/IMG]
The bulbs in the once blinker lights are 30-led white bulbs from superbrightleds.com. Don't remember they might be 3157, whatever fits the stock connector. I just switched the stock connectors out.
Ya need to swap out ur flasher relay to a relay that can cycle normally with the led bulbs u can get them from Autolumination.com
http://autolumination.com/equalizers.htm
Just look there were it says Toyota by the relay to see if it looks like the one in ur truck.
Hi/lo KIT you say? Not just a bulb that has two intensities? Like 55/100?
You can get HID H4 replacement lamps that are dual output from some suppliers. Some other methods used to get dual output in an H4 type lamp are the solenoid/motor method mentioned above and one mfg. uses(used?) a solenoid moved shade to redirect the light but I have not seen any ads from that chinese company for quite a while (the shade was reportedly problematic and prone to failure so it may have been dropped).
I ordered my h4 housing yesterday so I'll have hids installed on the baby runner next week. FYI I just set up a new vendor for hids so I have a full range of hid lights forsale now. I'll post pics as soon as I get them installed
