Coils vs. Leafs Pro's and Con's
Old Sep 24, 2003 | 10:29 AM
AznSky's Avatar
Just wondering what your guys' opinion is on which is better, for what reason? And which is worse.
Was thinkin of this cuz I overheard the guys in the cubicle across from me talking about leaf springs and solid axles
They work in the chasis department:cry: I wanna work there!!
Old Sep 24, 2003 | 10:30 AM
Robinhood150's Avatar
I think you should ask those guys!
Old Sep 24, 2003 | 10:34 AM
AznSky's Avatar
yea but they're busy right now, so I thought I'd get a little info, and then go into a conversation with them with some knowledge of what I'm talking about it my head.
keep in mind that I have no clue about either so if you are to explain something, please explain well. Thank you!
Old Sep 24, 2003 | 10:41 AM
Flygtenstein's Avatar
Coils require more engineering for links, lengths, separation distances and the like.
Leaves are more bolt and go, relatively speaking.
In the end, I think that you can make them flex, ride and handle about the same with some work.
Old Sep 24, 2003 | 10:53 AM
AznSky's Avatar
I guess I should ask how they function as well?
Old Sep 24, 2003 | 01:55 PM
kyle_22r's Avatar
leaf springs: cheap, easy to work with, but only flex well typically under loads
coil springs: expensive, requires control arms, but flex without weight on a wheel since they always push down
justdifferentials
14
Jun 11, 2017 08:36 PM
Lons81
Nov 23, 2015 09:25 AM
Jake28296
Sep 16, 2015 06:10 AM
