3.4L Swap w/2nd TRD supercharger
Old Feb 8, 2009 | 08:36 PM
BCAM's Avatar
What amount of body lift is needed to do the swap with a TRD supercharger without modifying the hood?
Old Feb 8, 2009 | 08:41 PM
okie81's Avatar
You're gonna need to cut a huge hole in the hood, then maybe with 2-3 inches of body lift, you may be able to squeeze it in.
What rig are you putting it in? Sometimes no extra clearance is needed....that's the beauty of the aftermarket supercharger
By the way, Welcome to YotaTech!
Old Feb 8, 2009 | 08:54 PM
olharleyman's Avatar
I am doing the same swap into a 2nd gen 4runner and atleast 1" is needed or a cut out in the hood and a nice scoop to cover the hole.
Old Feb 9, 2009 | 01:07 AM
BCAM's Avatar
Olharleyman - will you be cutting your hood or going with a body lift? If you go with the bodylift can you let me know when you are done that no hood modification is needed? Or if someone else has completed the swap with only a body lift can they let me know what body lift they used?
Old Feb 9, 2009 | 07:50 AM
Actually I am going with a 2" Chevy cowl hood after cutting the hole in the hood and doing the 1"body lift to get rid of the full lock turn rub of my 35 x 12.5's.
I will end up have 4" suspension and 1" body lift but it is going to be just a mall crawler from now on and tow rig when needed for my 93 SAS runner with 36's.
Old Feb 9, 2009 | 08:23 AM
Belize Off Road Team's Avatar
You could buy a Hilux TRD hood scoop and make it functional on your hood.
Old Feb 9, 2009 | 08:25 AM
Where you find that one?
Old Feb 9, 2009 | 08:39 AM
Well since he is in Australia he has access to a special TRD edition of the Toyota Hilux that comes with a killer package.
I wish i could get access to one but they only sell them in Australia. And only on certain packages.
Old Feb 9, 2009 | 10:22 AM
mt_goat's Avatar
2" BL without cutting hood (bonnet for you mate). I fit mine in with a 1" BL, but I had to remove the underhood insulation and some of the cross bracing. It clears by 1/4".
https://www.yotatech.com/990326-post171.html
Roger Brown (4crawler) will make custom BL kits. I'd probably get a 1.25 or 1.5 inch BL if I was doing it again. http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
Old Feb 9, 2009 | 05:59 PM
Tragic Drive's Avatar
Originally Posted by mt_goat
2" BL without cutting hood (bonnet for you mate). http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
No hood problems with this.
Old Feb 9, 2009 | 10:07 PM
syber_kowboy's Avatar
I bought a 1.5 from him and would recommend him to anyone looking for a good quality lift. However, I don't have a SC so I can't give you any advice on that.
Old Feb 16, 2009 | 12:53 PM
Check out this killer custom Lexus Hilux Vigo scoop in the UK for sale on Ebay right now:
I would buy it if i had not already orderd a chrome hilux vigo scoop for my hood after the swap.
1996Taco
Jul 20, 2015 12:02 AM
taller1
Jul 16, 2015 03:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Cplmike
Jul 8, 2015 08:47 PM
