3.4L Swap w/2nd TRD supercharger
You're gonna need to cut a huge hole in the hood, then maybe with 2-3 inches of body lift, you may be able to squeeze it in.
What rig are you putting it in? Sometimes no extra clearance is needed....that's the beauty of the aftermarket supercharger
By the way, Welcome to YotaTech!
Olharleyman - will you be cutting your hood or going with a body lift? If you go with the bodylift can you let me know when you are done that no hood modification is needed? Or if someone else has completed the swap with only a body lift can they let me know what body lift they used?
I will end up have 4" suspension and 1" body lift but it is going to be just a mall crawler from now on and tow rig when needed for my 93 SAS runner with 36's.
Well since he is in Australia he has access to a special TRD edition of the Toyota Hilux that comes with a killer package.
I wish i could get access to one but they only sell them in Australia. And only on certain packages.
2" BL without cutting hood (bonnet for you mate). I fit mine in with a 1" BL, but I had to remove the underhood insulation and some of the cross bracing. It clears by 1/4".
https://www.yotatech.com/990326-post171.html
Roger Brown (4crawler) will make custom BL kits. I'd probably get a 1.25 or 1.5 inch BL if I was doing it again. http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
2" BL without cutting hood (bonnet for you mate). http://www.4crawler.com/4x4/ForSale/ProductLine.shtml
No hood problems with this.
Check out this killer custom Lexus Hilux Vigo scoop in the UK for sale on Ebay right now:
I would buy it if i had not already orderd a chrome hilux vigo scoop for my hood after the swap.
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
